    Page 2 of 2 FirstFirst 1 2
    Results 21 to 26 of 26
    1. #21
      Sep 2016
      Bakersfield, CA
      I went to align them properly last night and noticed that for some reason, my low beam/hi beam is reversed where my dash light is concerned. In other words, when my low beams are on, the hi beam indicator on my dash is lit. When I switch to hi beams, the hi beam indicator goes off.
      I'm thinking this is the wiring of the adapter that comes with the Nokya conversion housings. Any idea how to test/verify this and correct it?
      EDIT: I think I found the answer: https://www.youtube.com/watch?v=hEkqssfg4Fk
      Only difference is that my male 3 prong plug has red on one side, then black in the middle, and a white opposite the red. So which 2 do I switch?
      http://www.TheFOAT.com/92GTA
      1969 Pontiac Firebird
      w/535ci IAII aluminum block, Dailey dry sump, Holley EFI (full road race build). Primer black w/black interior.
    2. #22
      Sep 2016
      Bakersfield, CA
      I swapped the red and white. Working just how it should now.
    3. #23
      So, you got 2 housing kits and 4 bulbs? I've been vaguely following all this.
      Instagram @projectgattago
      Dr. EFI
    4. #24
      Sep 2016
      Bakersfield, CA
      No, just 2. I only run the outboard hi/low beam lamps, not the inboard. I'm using the inboard lamp locations for ducting.
      These things are so badass all but the latest cars off the showroom floor on the road look like they are driving by candlelight lol! I got them aimed correctly and the cut-off is perfect for other drivers to not be blinded.
    5. #25
      So what would be needed for the typical 4 light setup?
      Dr. EFI
    6. #26
      Sep 2016
      Bakersfield, CA
      2 housing kits and 2 bulb kits.
      The LEDs can do hi/low so your inboards just would never go to high beam due to the factory wiring but all will work just fine.
