04-21-2019 #1Registered User
- May 2016
- Cadillac, MI
- 23
1968 Camaro convertible in Michigan $32,000
1968 Camaro convertible.
Too much to list but I will try.
Motor-original numbers matching 327 is on a stand. It ran but is in need of a rebuild. I video recorded the motor before I pulled it.
Currently has a 383 installed with efi. 1971 4 bolt main .030 over and clearanced for 6" rods. Eagle forged rotating assemble with esp rods. Comp cams cam, lifters, push rods, and roller rockers. Forged pistons. AFR aluminum heads. Edelbrock Air Gap intake. Fast EZ-efi set up. Tanks Inc in tank fuel pump. MSD distributor and 6al ignition.
Transmision-original munce 4 speed on rack with motor. T-56 6 speed transmision installed in car. Works and shifts but is difficult at times.
Brakes- Manual discs all the way around. Fronts are 2008 Corvette, rears are 1997 Camaro. It stops great.
Suspension- Front Global West Upper and Lower A-arms. Q1A coil over shocks. Hotchkis front sway bar, sub-frame connectors, x-brace, rear 2 inch drop springs.
Rear end is the original 12 bolt.
18" Chip Foose wheels.
04-21-2019 #2Registered User
- Jan 2019
- NC
- 13
