Results 1 to 3 of 3
03-26-2019 #1Registered User
- Dec 2018
- 12
wiring due master cylinder low level sensor in a 68 camaro
Hello to all that can help , Just installed new dse master cylinder/booster that has the low level sensor in the reservoir. Need to pick up pigtail/connector ,I see that there are to wires to this connector would you wire the old wire from the junction block switch to one wire and eliminate the other wire? Cannotfind schematic on this sensor ,the power brake master cylinder is C6 corvette thank you for your help
03-27-2019 #2
