    Page 9 of 10 FirstFirst ... 4 5 6 7 8 9 10 LastLast
    Results 161 to 180 of 183
    1. #161
      May 2015
      Georgia
      Quote Originally Posted by markaaron80 View Post
      Attachment 203119Attachment 203119
      Hi Frank. Is the carbon fiber version the only one that offers the moved MAF boss? Want to order something, just curious if the Carbon fiber is the option that will work the best, or if aluminum will work as well.
      I'm ready to pay you Frank. I want the anodized black aluminum cold air intake for LS3 in my 69 camaro. I do have a high mount power steering reservoir tank. So I'm assuming I need the MAF moved slightly.
      Please let me know how you want payment.
      Thanks, Mark
    2. #162
      Thanks, Mark
      I ran into the same issue, but there is enough clearance in my case where I can plug the maf sensor and barely clear the PS reservoir from rubbing. Frank also made a few changes for me and extended the pipe 2" and added a vent tube. The extension was after the MAF. The added length was due to my larger C&R radiator with the oil cooler. Careful with moving it too much, per the GMPP instruction it should be in the middle of a min 6" of tube and it should be within 10" or so of the TB. This was an early version and before I had the high mount Holley setup. Glad to see Frank has a variation for this now.
    3. #163
      May 2015
      Georgia
      What are you using the vent tube for??
    4. #164
      May 2015
      Georgia
      I went through and read entire thread. I see the website now. I'm just a little worried because I had to trim underside of hood a tad to keep bottom side of hood from touching the 102 mm throttle body. Didn't know if you thought that would be an issue with the length of the cold air intake pipe?
    5. #165
      It goes to my Pass side valve cover for the PCV system. I use a catch can for the dirty side. I may redo this at some point, but this is the how the instruction for the GMPP setup has it for my LS3.
    6. #166
      Jun 2016
      68 LSA yet my friend ??
    7. #167
      Jul 2010
      south gate
      Quote Originally Posted by nickburns31 View Post
      Sorry no LSA .
      Excuse all late responses , alerts are not functioning
    8. #168
      Jul 2010
      south gate
      Thanks, Mark
      Hi mark , my alerts are not functioning but PM me so we can check details
    9. #169
      Jul 2010
      south gate
      Carbon fiber comes in all 3 variables , no MAF , MAF at 4.5” OC and 8.5” OC .
    10. #170
      Jul 2021
      Houston, TX
      Hi Frank - do you do cold air setup for a 69 Camaro with an LSA engine?
    11. #171
      Jul 2010
      south gate
      Quote Originally Posted by samvera31 View Post
      Sorry just LS and LT4 but many have used my LS and cut to fit LSAName:  IMG_2223.JPG
    12. #172
      Feb 2019
      I just wanted to give a big thanks to Frank and the cold air kit he sold me. Frank is the best vendor I have bought from and will return phone calls on the weekends to satisfy a customer. Thanks again.
    13. #173
      Jul 2010
      south gate
      Quote Originally Posted by Hooded View Post
      Thank you for your support and your feed back . My slogan is “ if I’m alive I’ll take care of you if not your on your own “
    14. #174
      Jul 2010
      south gate
      “NEW LOW PRICE $899 +shipping “ If you have been waiting on the sidelines for one of these #grayareasteelcompany #coldairintakes Now is the time . We will no longer make Aluminum units and down to the last few on those . Big price reduction sale -$200.00 Bringing the best value to our customers . ________________________“ Best LS Swap CARBON FIBER Cold Air Intakes on the market” $899 + shipping.
      For any one running an LS , MAF or no MAF on your 1967 1968 1969 camaro / firebird . Now offered in FULL CARBON FIBER. kit comes with everything needed to install.
      Perfect for 99% of LS swap radiators, clears most oil coolers on drivers side Radiator tank.
      Works perfect with fast , Holley sniper and most low to medium raised intakes . “Please specify if using a top mount power steering pump reservoir ( close to TB ) as this kit uses different offset on MAF boss.
      Accommodates a large variety of setback motor mounts , subframe variations , after market intakes ( Holley , precision etc.. )
      “ Don’t forget to check us out at GrayAreaSteel.com link in bio “
      Kit includes everything needed for install.
      1 . 4” Carbon Fiber Tube - Matte finish
      2. Two 4” silicone coupling
      3. Four T bolt clamps
      4. Four mounting tabs
      5, two Carbon fiber driver and passenger heat shields
      6. All necessary hardware
      7 . GM throttle body sleeve adapter kit
      8. K&N Ru-3101HBK oil free Filter
      #grayareasteelcompany #carbonfiber #lsswap #customcoldairintake
      #customcoldairintakes #carbonfiberintaketubes #customcarbonfibercoldairintakes #firstgencamaros #1969camaro #1967camaro #1968camaro #lscoldairintake #customintakes #LSintake #lsswap ..Name:  IMG_0908.JPG
Size:  706.8 KBName:  IMG_0909.JPG
Size:  664.7 KBName:  IMG_0923.JPG
Size:  620.7 KBName:  IMG_0926.JPG
Size:  645.0 KBName:  IMG_8836.JPG
Size:  1.06 MBName:  IMG_8831.JPG
Size:  943.2 KBName:  8DABBADD-A204-4177-8301-A960F0ED9560.jpg
    15. #175
      Jul 2010
      south gate
      Oct 2019
      Without digging through the entire post, what's the discounted price on aluminum units while they last?
    17. #177
      Jul 2010
      south gate
      Quote Originally Posted by Kyle Simpson View Post
      Hi kyle no discounted rate , they’re actually more of rare item now that they will be off the menu still $850 plus shipping
    18. #178
      Sep 2021
      I need this in my life!Name:  Screenshot_20221205_150537_Instagram.jpeg
    19. #179
      Jul 2010
      south gate
      Quote Originally Posted by Junyor757 View Post
      Very nice
    20. #180
      Jul 2021
      Houston, TX
      Frank - can the LT4 / LT5 cold air intake work on an LSA engine if we modify the intake?
      Sam V.
    Tags for this Thread
