    Page 14 of 19 FirstFirst ... 4 9 10 11 12 13 14 15 16 17 18 19 LastLast
    Results 261 to 280 of 363
    1. #261
      Sep 2017
      Wing windows and carbon mirrors are on. Also my re barrelled wheels are back from forgeline.Name:  IMG_20220522_181254.jpg
Size:  246.6 KBName:  IMG_20220522_220722.jpg
Size:  263.7 KBName:  IMG_20220520_195820.jpg
Size:  293.5 KBName:  IMG_20220520_195811.jpg
      TANKMASTERJ
      Jasons Toys
      2000 HD Softail
    2. #262
      Jul 2018
      beautiful
    3. #263
      Jan 2021
      Alabama
      Love those mirrors. Great choice.
    4. #264
      Sep 2013
      sw Kansas
      Each time I check in I expect to hear sound.
    5. #265
      Sep 2017
      Thanks guys. If I knew how to post sound I'd do it
      TANKMASTERJ
      Jasons Toys
      2000 HD Softail
    6. #266
      Sep 2017
Size:  496.5 KBName:  IMG_20220528_155503.jpg
Size:  390.5 KBName:  IMG_20220528_155453.jpg
Size:  396.1 KBName:  IMG_20220528_194049.jpg
Size:  372.5 KBName:  IMG_20220528_194041.jpg
      Installed my driver seat. Seats are Braum Alpha X.
      Very nice for a vinyl I got no complaints. Will test drive tomorrow.
      Also got my center dash piece in it's Anvil Carbon.
      I have to say both the mirrors and center dash are anvil and I'm not that impressed with the qualities.
      Seriously the mirrors you got to glue the bracket in that holds it to the car and you glue the bezel in. Both with epoxy but for the price just not impressed. The center dash you don't get anything to attach it to the car. Undrilled holes because my entire build is stainless bolts everywhere so it's ok. But it still needs a rubber windlace around the outer perimeter.
      TANKMASTERJ
      Jasons Toys
      2000 HD Softail
    7. #267
      They look good
    8. #268
      May 2012
      Kansas City, Missouri
      That sucks when you pay that much for speciality parts and you have to still engineer them to mount on the car. Car looks good. Good luck on that first drive. Its exciting and scary lol
    9. #269
      Sep 2017
      Well after a commercial napa 930 CCA struggles to start my high compression LS7. Im wavered on a single North Star with 1130 CCA or just run 2 Continentals that I had already new. They are 680 each. So I used my original battery tray and a new dynacorn tray and fabbbed a bracket out of 3X5X1/4" thick angle I had and mounted it between my bolt in cage.
      And instead of a battery number from one to the other I just ran another #2 up to the firewall bulkhead. So each battery has its own hot to the firewall.
Size:  208.3 KBName:  IMG_20220604_134330.jpg
Size:  403.7 KBName:  IMG_20220604_134333.jpg
Size:  351.2 KBName:  IMG_20220604_135249.jpg
      TANKMASTERJ
      Jasons Toys
      2000 HD Softail
    10. #270
      Sep 2017
      Well I'm not great at pictures but here the Spoilers by Randy added today.
      I like if for a bought one. It still like to add a custom pro touring one later but for now this worksName:  IMG_20220715_200802.jpg
Size:  347.5 KBName:  IMG_20220715_205841.jpg
Size:  186.5 KBName:  IMG_20220715_200809.jpg
      Also having a little driveability issues. Like several have had in older posts I read when in the throttle and letting off or down shifting up to a stop light it wants to die. Runs great at idle, part throttle over half throttle even WOT but then falls on its nose when I let off. I'm using the E38. Haven't had any tuning done yet other than the ECU came from a wreck z06 that ingot as a package.
      Considering Gwatney Performance little rock unless someone has another in central Arkansas that's good.
      Also got to fab a stainless grill still yet and install seatbelts and rear seat. Got side glass, door panels and hardware and cold ac!
      Jason
      TANKMASTERJ
      Jasons Toys
      2000 HD Softail
    11. #271
      If you plug in a generic code reader that has live data so that you can confirm all of the sensors are working, it's very likely your tune. I'm sure that you have added several parts that weren't in the original tune so getting it adjusted will be key. Love that spoiler.
    12. #272
      Oct 2016
      Love it ! Can't wait to see her running, congrats Jason, you made a huge build !
    13. #273
      Sep 2017
      Ive got a bosch tech 2. From what I can tell everything looks normal but I'm no expert. I've got a local guy here in conway that's going to hook to it and ride with me to data log and see what he sees.
      TANKMASTERJ
      Jasons Toys
      2000 HD Softail
    14. #274
      Sep 2017
      Quote Originally Posted by berdunord View Post
      Thanks Bernardo. I'll eventually get a video posted. Working on slight tuning issues at the moment. Hopefully get my back seat, seat belt bar in this weekend then all I'll lack is grille and stereo!
      As you know it's never done, I see your doing no another turbo too!
      TANKMASTERJ
      Jasons Toys
      2000 HD Softail
    15. #275
      Oct 2008
      Toronto, Canada
      Jason
      I had a problem with my car stalling upon slowing down after I pressed the clutch in coming to a stop/light. I found out it had something to do with DFCO- deceleration fuel cut off. I'm not running a GM ecm, using a Fitech 70050.
      https://forum.hptuners.com/showthrea...4-What-is-DFCO
      Not sure if this is your issue but maybe worth a little investigating or having a qualified tuner check this out.
      Simon
    16. #276
      Sep 2017
      Thanks for the tip I'll definitely look at that.
      Jason
      TANKMASTERJ
      Jasons Toys
      2000 HD Softail
    17. #277
      Sep 2017
      Ok so I'm tinkering again. I installed my LS7 emblems and I think they look pretty good. I also cut a grille pit of some aluminum mesh. I lined the outer perimeter with se black rubber for the pop effect next to the aluminum grille and white grille surround.
      I'm happy with the end result.Name:  IMG_20220802_205113.jpg
Size:  218.2 KBName:  IMG_20220802_203437.jpg
Size:  224.2 KBName:  IMG_20220802_203443.jpg
Size:  158.2 KBName:  IMG_20220802_204938.jpg
Size:  232.7 KBName:  IMG_20220802_225021.jpg
      TANKMASTERJ
      Jasons Toys
      2000 HD Softail
    18. #278
      Sep 2013
      sw Kansas
      Grille looks good.
    19. #279
      Jan 2021
      Alabama
      Digging that front grille Jason. Looks great.
      Question on your seats, and how tall are you? Im wondering how you are feeling about your driving position?
      I am 6'3" with similar style seats. 300 miles in now and just feel like I am sitting a little high. Considering making a change but outside of a major change at the base probably my only option is removing the slider and going to a fixed location. That would probably put me about an inch lower.
    20. #280
      Sep 2017
      Quote Originally Posted by wareaglescott View Post
      Bad news I'm only 5 10. Braum Alpha X racing seats with there sold planted brackets fit me perfect. But I have tracks mounted as far back as they go. A taller guy would struggle with my setup. Probably have to remove the planted brackets or have to chop them down and re fab to make it happen.
      I had the pro car 90 seats and brackets, they did with lower
      Hope this helps
      TANKMASTERJ
      Jasons Toys
      2000 HD Softail
