    Page 15 of 19 FirstFirst ... 5 10 11 12 13 14 15 16 17 18 19 LastLast
    Results 281 to 300 of 363
    1. #281
      Dec 2015
      Arkansas
      Ok so I'm tinkering again. I installed my LS7 emblems and I think they look pretty good. I also cut a grille pit of some aluminum mesh.
      Man, great progress Jason! That grill looks so good as well. I have an extra ‘67 grill that I am modding - can I ask what the black surround material is?
      '67 Camaro SS - Currently in build stage but making progress!
      **Brett**
    2. #282
      Sep 2017
      Brett
      it's just some rubber edging material that resembles pinch weld molding. I bought it from custom car grills dot com. They sell the mesh and the edging in couple sizes.
      Jason
      TANKMASTERJ
      Jasons Toys
      2000 HD Softail
    3. #283
      Dec 2015
      Arkansas
      Brett
      Jason
      Nice, thanks for the info
      **Brett**
    4. #284
      Sep 2017
      Each time I check in I expect to hear sound.
      If knew how to add sound I'd add it lol
      TANKMASTERJ
      Jasons Toys
      2000 HD Softail
    5. #285
      Sep 2013
      sw Kansas
      Jason, under hit reply, go to advanced. Under "manage attachments", click the box and then navigate to where ever you have your sound file located and double click it. As long as the file isn't too large, it should load. Then we can hear it run.
    6. #286
      Oct 2011
      Upload a video to YouTube then copy and paste link
    7. #287
      Sep 2017
      https://youtu.be/-erNtAE_QVo.
      Ok I finally took a few minutes to figure out to post a video to youtube and copy and paste the link .
      Hope it works. This video is early summer before my re barrelled forgelines were back and ally was still undone but you can hear it.
      I'll slowly work on the youtube channel it's called White Lightning 67 Camaro
      TANKMASTERJ
      Jasons Toys
      2000 HD Softail
    8. #288
      Sep 2013
      sw Kansas
      Very good.
    9. #289
      Oct 2016
      Awesome !
    10. #290
      Jan 2010
      Sounds fantastic!
    11. #291
      Sep 2017
      Alright guys I'm building out my amp and stereo setup and my rear shoulder belts. setupName:  IMG_20220903_162509.jpg
Size:  214.1 KBName:  IMG_20220903_220122.jpg
Size:  229.1 KBName:  IMG_20220903_221009.jpg
      Now I ordered morris classic shoulder belt kit for the rear. I want to say outstanding kit and quality but it wouldn't work with my ridetech bolt in cage and my custom package tray. So rather than mount the shoulder ratchets on the outside of the car I mounted both in the center between the speakers and fabbed up appropriate bracing under the package tray out of 2X2x 1/4 aluminum angle tying the two ratchets to each other and then 1/4" X2" flat from that down to my battery trays which is made of 3X5 aluminum angle and bolted between the cage points in the trunk. I didn't get good pics of the mount or the ratchet part of the belts installed but will add those tomorrow.
      For stereo I'm trying the Mark 4 out of sight audio and running a Hertzs HCP 5D amp. I've got Hertz Milles for the deck in 6X9s and Hertz Milles for the kick panels but I've yet to install those.
      As for the cars driveability I had issues with limp mode at 6 grand and no matter what we did tuning it wouldn't leave. Engine came with a gold blade TB when I got it. Ran the VIN and it called for the Silver Blade. Read forums online where other guys had the same issue trying to go to the gold. Depending on which E38 they had. So swapped to the silver blade, did a TB re learn and wallah it runs hard to 7500 now.
      Still got a slight lean issue on back one due to very tiny hairline cracks on the runners right behind the intake bolts. Will be swapping to probably an MSD.
      Or do you guys think Fast or MSD. I don't care about max effort at 7500 or 8 grand. It's a street car that will see auto x, drag and a little road racing. But predominantly street so I need torque and power 3 -7500.
      TANKMASTERJ
      Jasons Toys
      2000 HD Softail
    12. #292
      Apr 2016
      Can't go wrong with either, the MSD typically make a little more HP, just be sure you have enough hood clearance and which one works with your current fuel rails.
    13. #293
      Sep 2017
      E Stopp brake
      Got my Estopp mounted. Put it on the driver's side frame rail of my Speedtech sub frame. Use studs I already had through the floor from my front door bar cage mount setup and used holes that came at the back of the subframe to mount the bracket. turned out pretty clean.Name:  IMG_20220906_213304.jpg
Size:  207.2 KBName:  IMG_20220907_191134.jpg
Size:  118.7 KBName:  IMG_20220907_191145.jpg
Size:  157.1 KBName:  IMG_20220907_191206.jpg
Size:  248.5 KBName:  IMG_20220907_191214.jpg
Size:  193.7 KBName:  IMG_20220907_191154.jpg
      TANKMASTERJ
      Jasons Toys
      2000 HD Softail
    14. #294
      Jul 2018
      E-Stopp looks great, I need to install mine and have been researching how everyone else mounts theirs. I appreciate the pics.
    15. #295
      Sep 2017
      Quote Originally Posted by Just 1 More View Post
      Buy the CPP kit. It has that long skinny bracket in my pics. I jest welded small fabbed brackets up to mount to my sub. There universal cable kit was also great.
      Jason
      TANKMASTERJ
      Jasons Toys
      2000 HD Softail
    16. #296
      Jul 2018
      Jason
      I didn't even know that existed.. Thank you Soooooo much.
    17. #297
      Sep 2017
      LS Fest East
      Well made it to 2022 with white lightning.Name:  IMG_20220909_145603.jpg
Size:  369.7 KBName:  IMG_20220909_145918.jpg
Size:  530.4 KBName:  IMG_20220909_183747.jpg
Size:  326.3 KBName:  IMG_20220909_145712.jpg
      TANKMASTERJ
      Jasons Toys
      2000 HD Softail
    18. #298
      Sep 2013
      sw Kansas
      Congrats.
    19. #299
      Congrats!! It looks fantastic out in it's natural habitat.
    20. #300
      Sep 2017
      Thanks guys as you all know it's a long time coming
      TANKMASTERJ
      Jasons Toys
      2000 HD Softail
