    Page 7 of 9 FirstFirst ... 2 3 4 5 6 7 8 9 LastLast
    Results 121 to 140 of 165
    1. #121
      Sep 2017
      I'll check out your build thread
      Jason
      TANKMASTERJ
    2. #122
      Sep 2017
      Yeah. Brett iam sure. Glad I did. It looks right now
      Little by little
      Jason
      TANKMASTERJ
    3. #123
      Oct 2016
      What an awesome job Jason ! Your car will be better like new ! Can't wait to see it running
    4. #124
      Jan 2021
      Alabama
      War eagle scott I used a gallon or 4 one liter bottle that they send .
      Great thanks. That is how many I have! haha
    5. #125
      Oct 2011
      Tampa
      Nice paint work Jason!
    6. #126
      Sep 2017
      Ok so I got the interior floor sealed, sanded and seam sealed. Partially taped. Getting ready to spray lizard skin sound deadener and lizard skin ceramic heat barrier.
      Also got my nitros mounted on some Forgeline ZX3 Rs.
      Titanium centers and black barrels.
      275-40-18 fronts
      295-45-18 rears. ( I wanted the height of the 45 @28.40" tall. I built thee entire car around a. 28" tire the 315s.
      I wanted nthe 315-40 rears but nitro is out of stock and not saying when
      I could ha e got a drag radial or dot road race type but I wanted a street tread so these will do to finish the build and roast them away while waiting on the 315-40-18.
      The last photo is the 275-40-17 that I had on the car before. Lot taller and wider. Name:  IMG_20210807_125919.jpeg
Size:  83.9 KBName:  IMG_20210807_125924.jpeg
Size:  61.1 KBName:  IMG_20210806_095658.jpeg
Size:  98.5 KBName:  IMG_20210806_092920.jpeg
Size:  140.6 KBName:  IMG_20210806_231703.jpeg
      TANKMASTERJ
    7. #127
      Sep 2017
      Ok so Iam OCD with the car. I just sprayed lizard skin sound deadener. Tomorrow will be lizard skin ceramic heat barrier. Then when I assemble the car Iam still going to use dynamat. Name:  IMG_20210811_155544.jpeg
Size:  102.0 KBName:  IMG_20210811_175332.jpeg
Size:  109.6 KBName:  IMG_20210811_175158.jpeg
Size:  66.5 KBName:  IMG_20210811_175204.jpeg
Size:  66.6 KBName:  IMG_20210811_154047.jpeg
Size:  49.3 KBName:  IMG_20210811_170547.jpeg
Size:  68.4 KBName:  IMG_20210811_175134.jpeg
Size:  89.9 KBName:  IMG_20210811_175204.jpeg
Size:  66.6 KBName:  IMG_20210811_175137.jpeg
      TANKMASTERJ
    8. #128
      NJ
      Looks great! How much product did you wind up using to get all that covered?
    9. #129
      Jan 2021
      Alabama
      Im spraying my ceramic insulation today after doing the sound stuff two days ago. How did you make out with the little depth gauge? I didn't have a ton of success getting consistent results! Really like the way it sprays on though!
    10. #130
      Sep 2017
      Under the car has two coats raptor. First coat 1 gallon. Second coat 3 quarts.
      The Lizard Skin ceramic heat insulator in the car I used 2 gallons and really could have used another half gallon. But I sprayed even up under the areas between the back glass and trunk as well as inside of rear quarters and under the dash as far up as to where paint stops where dash meets windshield.
      I didn't spray inside my doors yet. I'm going to just sand them and use some rate can undercoat then dynamat there.
      - - - Updated - - -
      Quote Originally Posted by wareaglescott View Post
      Yes it is hard to be consistent. I've used wet mil guages my whole life on epoxies and urethane as well as zinc rich coating due to being in the water tower construction business
      TANKMASTERJ
    11. #131
      Sep 2017
      I'm it does also have excellent adhesion for a water based product. And if you get it on paint you better clean off quick. It's fast!
      TANKMASTERJ
    12. #132
      Jun 2015
      Country Flag: New Zealand
      275-40-18 fronts
      have you mocked up with these yet?
    13. #133
      Sep 2017
      Quote Originally Posted by Gmc427 View Post
      Yes. The car is built around them. My rear is very narrow. 52 7/8" narrow. The rear wheels were mocked with a 3" spacer. To get me where I want to be and compensate for the 6.97 backspace. I'm going to use the spacers as to mill off a few thousands or 1/8 or whatever to fine tune where I want them. Then I'll re barrel the rears accordingly. I did that because I got the ZX3r wheels for 2800 new. .
      I want 315 on rear but they are long back orders nkw so 295s are temporary.
      The height of them is I built the car for a 26" front height and a 28" rear. I had 24.5 fronts and 25.5 rears and it was way to low and I had to floor jack to get it on my challenger CL10v3 lift. That was t going to work for me and it had really no rake or stance. So alot of math and tape measure on to conclude what I really wanted.
      TANKMASTERJ
    14. #134
      Dec 2015
      Arkansas
      Looking good Jason! Iíd be afraid of getting it on the paint somewhere thatís going to be nice! I know you mentioned Dynamat but have you looked at Kilmat?
      '67 Camaro SS - Currently in build stage but making progress!
      **Brett**
    15. #135
      Sep 2017
      Quote Originally Posted by Smooth67 View Post
      I haven't looked at kilmat. But I have a box of dynamt my paint shop bought and used in the roof so ingot some left
      Overs there and ingot another box I ordered way back when I dismantled the car. So expensive as it all is it's going in the car lol!
      Do holler if you come this way sometime Brett
      Jaaon
      TANKMASTERJ
    16. #136
      Dec 2015
      Arkansas
      Jaaon
      Well in that case, Dynamat it is!! Will definitely hit you up when Iím down there.
      **Brett**
    17. #137
      Sep 2017
      Ok I wanted to start wiring. So I mocked up the vintage air unit and removed. Enlarged the bulkhead wiring hole and mocked up the. AAW wiring bulkhead. I then realized I need to mock up the clutch kit from bowler.
      I didn't like the geometry or how offset it was from the factory hole. So I sliced the bowler bracket shortened 1/2" and slid it t the center of the car 3/8" for perfect alignment. Re drilled the clutch pin hole for the master rod and all works flawless.
      Now remove all that and begin dynamat extreme.
      I got the first box of dynamat empty. My paint guy got a box and. Applied to the inside of roof. The balance made it from under the dash where the defrost tubes hit to about the front of my shift hole.
      Box 2 begin!Name:  IMG_20210821_201114-1.jpeg
Size:  51.8 KBName:  IMG_20210821_201041.jpeg
Size:  50.5 KBName:  IMG_20210826_200717.jpeg
Size:  63.0 KBName:  IMG_20210826_193029.jpeg
Size:  58.6 KBName:  IMG_20210827_213148.jpeg
      TANKMASTERJ
    18. #138
      Sep 2017
      Now I got bored laying down looking under the dash gimped up in a fetal ball so I thought I'd install my billet ATS spindles and Aero 6 Caliper and Rotor lot along with the Forgeline ZX3R so I could get a visual.
      I dig the wheels big-time.
      Last photo was quick shot of firewall white I sprayed just to help visibility while i mocked up everything and it really helped. Now the dynamat is in there it's not so great on visibility.Attachment 191726Name:  IMG_20210821_202113.jpeg
Size:  92.2 KBName:  IMG_20210821_203050.jpeg
Size:  68.3 KBName:  IMG_20210821_203056.jpeg
Size:  67.9 KBName:  IMG_20210821_202146.jpeg
Size:  69.4 KBName:  IMG_20210821_203056.jpeg
Size:  67.9 KBName:  IMG_20210815_190631.jpeg
      TANKMASTERJ
    19. #139
      Sep 2017
      The 275-40-18 Nitto 555 G2 tires look wide and good on the subframe. I think speed tech says you can run a. 9 or 9.5" wide wheel but I'm running a 10".
      It turns lock to lock both ways with about an inch of clearance.
      I'm tickled.
      Cannot wait to get my engine harness on, AC I'm, and other small stuff done so I can put the subframe back in to see wheel fitment in the wheel well.Name:  IMG_20210821_203039.jpeg
Size:  106.3 KBName:  IMG_20210821_203133.jpeg
      TANKMASTERJ
    20. #140
      Oct 2016
      Jason what you do is awesome, can't wait to see all assembled
      Ber
