Results 1 to 20 of 119
03-19-2019 #1Registered User
- Mar 2017
- Omaha, NE
- 54
1979 "Transmarrow" Mid-engine LQ9 build
Well my name is Dalton, I have spent a lot of time on this site, in particular the suspension thread. I figured its about time I show some people what I have been working on.
Things on this build just kind of fell into place, I was looking for a new project to start that could give me a sort of rolling business card for the fabrication business I am starting. I thought it would be neat to do a kit car (Like a Factory Five 818) but that is out of the current budget. Well through some vehicle trading, an 2002 Subaru Wrx landed into my possession. I immediately started doing some research on what components are used for their kit cars. and what it would take to build a tube frame from scratch but mimic the overall idea of what Factory Five has done with their 818. As I was looking into all of this I got a call from a friend who owns a body shop, he said he was given a Trans Am that had a pretty rust free body except for the floors. He said I could have the car minus the front subframe assembly. So, I made up my mind that I was going to do an FFR818 with a Trans Am body.
Initially this was going to use the Flat 4 turbo charged engine, but having done a few LS swaps I began looking into what companies if any made adapters for a WRX engine. After contacting several manufacturers and I found a company in Australia that makes the bellhousing adapter and flywheel. It takes about 2 months to get the part so in the time I picked up a mock up block and made a temporary adapter out of plywood. Enough of me rambling, here is a progression over several months.
Just a few things as far as the end goal on this car. We all have to have goals....
Car will have 4-4.5" ride height, and with chopping the roof 3.5" in the back and laying down the A pillar at that ride height the roof will be 44' from the ground.
I am aiming for around an 84" track width, wheelbase of 118"
18 or 19" wheels 305-315 wide square setup
Car is running front and rear spindles from an 02 WRX with some modifications. Push rod suspension.
Subaru WRX 5 speed transaxle, with rear output deleted.
Gen 3 LQ9 6.0 with L92 heads, plan is to run the bald eagle cam from Texas Speed. As of right now I am thinking of using either the Holley hi ram, or Edelbrock crossram intake. Hoping to see around 550hp at the crank
I hope all said and done I am somewhere between 2200-2500 pounds minus driver.
I will try and regularly update you guys to what I am doing. Rear suspension should be done in the next 2-3 weeks minus having coilovers.
Attachment 162627 Attachment 162628Attachment 162629Attachment 162630Attachment 162631Attachment 162633Attachment 162634Attachment 162635Attachment 162636Attachment 162637Attachment 162640Attachment 162632Attachment 162639Attachment 162648Attachment 162649Attachment 162650Attachment 162657Attachment 162658Attachment 162659Attachment 162660Attachment 162661Attachment 162645Attachment 162646Attachment 162647Attachment 162644Attachment 162642Attachment 162643Attachment 162651Attachment 162653Attachment 162656Attachment 162655Attachment 162654Attachment 162652Attachment 162638
