    Results 1 to 20 of 22
    Thread: ASA Pro Truck
      Mar 2019
      North Bay Area
      ASA Pro Truck
      I picked up a rolling chassis a few months back from a friend in Alameda, CA. I've always been interested in the older Spec Trucks and finally found a deal that I couldn't pass up. The idea was to make an autocross and/or road race build, but I'm mostly looking to learn as much as I can along the way.
      Somewhere down the line, I'd like to put a pre 1975 CA registered truck cab on the chassis and make it 'street-legal'. Not sure if anyone else in this form has done that, but the "Nascarlo" episode on RoadKill got me thinking...
      So far:
      -5.3L LM4 out of a wrecked Buick Rainier (all stock).
      -4L80E with manual valve body (I know it should have been a Jerico, but I had the 4l80e laying around)
      -GMC Sierra (Spec) Brakes.
      -Quick change rear end.
      Next Up (Looking for input if you have any ideas)
      -Shifter = Ratchet or Gated?
      -Trans Cooler = Would prefer to have a fan and/or shroud set up, but any recommendations are welcomed.
      -Motor/Trans Mounts = Is solid the best way to go? The motor is stock, so shouldn't make more than 315hp all in. Is rubber, poly, or solid the best way to start?
      Click image for larger version.
ID:	161997Click image for larger version.
ID:	161998Click image for larger version.
ID:	161999Click image for larger version.
ID:	162000Click image for larger version.
ID:	162001Click image for larger version.
ID:	162002Click image for larger version.
ID:	162003Click image for larger version.
ID:	162004Click image for larger version.
      Mar 2004
      Mid-Michigan
      Nice project! I love off the wall projects!
      I like a ratchet shifter myself. Very straight forward to use, just yank it back and smack it forward to upshift. Real easy.
      I built a complete shroud for the cooler and fan on my van build. With that said my '56 wagon has the cooler on the pass. side frame rail with no fan.... no heating issues at all.
      For mounts think about doing a rubber on the passenger side and a solid on the drivers. A cheap and affective way to keep the engine from rolling but it also cuts done on a LOT of the harshness you will get running all solids.
      Mark
      Mark:
      This my Bad Ast thread...
      This is my Fotki album...
      http://astroracer.fotki.com/
      Mar 2019
      North Bay Area
      Thanks for the heads up Mark. I was leaning towards a ratchet shifter as well.
      Interesting thoughts on the motor mounts, I didn't know you could mix solid/rubber mounts.
      Thanks again.
      Mar 2004
      Mid-Michigan
      No problem. Been doing the rubber/solid thing for a long time. You still get a little vibration but it's nothing like having full solids.
      I also tried polyurethane vs. rubber trans mounts. My '02 T/A would rip up the rubber trans mount in a couple of thousand miles. The poly would last longer but it also induced a lot of vibration. The T/A had a torque tube rear suspension so that had a lot to do with destroying the rubber mounts. With a solid in the left front you may want to consider a rubber trans mount as your suspension will not put the stress a torque tube will into it.
      Mark
      Mark:
      Mar 2018
      la mesa, CA
      If you are on Insta or on Facebook there is a guy I have been following since the beginning who has done this in Colorado.
      https://youtu.be/ranP0GCXuX8
      https://www.instagram.com/officialpro10/?hl=en
      Follow my Instagram
      And my build on here
      Oct 2018
      Phoenix, AZ
      Came here to say the same thing ^. But yeah look at what he has done. It's a clever blend of parts to make an animal of a truck. Hell I'm starting to think I should have started with one of these at this point.
      Mar 2019
      North Bay Area
      Wow, thanks for the heads up guys! Exactly what I was looking for. I saw an older YouTube video from his C10 build at the Pikes Peak track, but just gave him a follow on Insta.
      I've been following your F150 build as well, such a cool project.
      Mar 2019
      North Bay Area
      Picked up a 1964 Willy's J300 truck Cab with a clean title last weekend! The idea is to do a 'skin-graft' of sorts. Will keep the fiberglass s10 panels on the bed, but hoping get the cab and front end to fit.
      Per your recommendation, I checked out Official Pro C10 and a few other places for ideas, but any recommendations are welcomed!
Size:  409.9 KBName:  willys2.jpg
Size:  398.9 KBName:  truck2.jpg
      Feb 2013
      Very cool!
      Ridetech Suspsension
      Tech Specialist
      Phone: 812.481.4734
      Project Fox
      1979 Trans Am
      Jun 2017
      Edgewater Co.
      What Josh said, I can't wait to see the Jeep body go on it.
      Joe
      Oct 2018
      Phoenix, AZ
      Very interesting idea for a body. If you make rear fenders with similar flares that would be the icing on the cake!
      Mar 2019
      North Bay Area
      Quote Originally Posted by Josh@ridetech View Post
      Very cool!
      Thanks Josh, will reach out after initial testing...would be great to get your input on suspension set up.
      Feb 2013
      Quote Originally Posted by woody.rbsn View Post
      No problem at all! Give me a call anytime.
      Tech Specialist
      Phone: 812.481.4734
      Project Fox
      1979 Trans Am
      Mar 2019
      North Bay Area
      .Name:  reno_b.jpg
Size:  88.7 KBName:  reno_a.jpg
Size:  99.5 KBName:  reno_c.jpg
Size:  78.7 KBName:  reno_d.jpg
Size:  94.9 KBName:  reno_e.jpg
Size:  85.0 KBName:  reno_f.jpg
      Mar 2019
      North Bay Area
      First few autocross events are in the books! Ran well all day. Doing cam, springs, injectors and regulator next. Was lucky enough to get my hands on some used Pirelli slicks from a local TA2 team.Name:  IMG_5482.jpg
Size:  172.2 KBName:  IMG_5481.jpg
      May 2013
      SE Michigan
      I love it!
      NC
      Awesome, just awesome.
      Mar 2019
      North Bay Area
      A few photos from a local road rally last month. I lost the air filter a few miles into the drive, but a motorcyclist picked it up and we zip tied it back on at the first stop. The truck did great.
      Name:  Screen Shot 2021-03-18 at 6.56.21 AM.jpg
Size:  205.4 KBName:  Screen Shot 2021-03-18 at 6.55.53 AM.jpg
      Very cool. Was the chassis built on a G-body frame?
      Mar 2019
      North Bay Area
      Hey Andrew, good eye. I'm not sure what the exact class rules were for the chassis, but it was based on a G-body frame.
