    Results 1 to 8 of 8
      Apr 2015
      Tuff Stuff booster 2229 install
      I am sure a lot of you have run into the same situation and I hope someone has a solution.
      I will be installing the 2229 booster with the DSE brackets on my 69 camaro. The booster has a long rubber boot that will need to extend through the firewall by an inch or two. I have seen posts where folks have had to enlarge the opening in the firewall so it will fit.
      Here is my issue, the rubber boot will not seal against the firewall, just pass through. How do you make this opening weather proof? I do not want water or engine smells getting into the cabin.
      Thanks for your help
      There is a seal plate and seal to go with the angle brackets. See this install instructions for details:
      https://www.detroitspeed.com/img/pro...nder%20Kit.pdf
      Note that the %20 in the URL are spaces, may need to edit the above link for it to work:
      https://www.detroitspeed.com/img/pro...raking/Detroit Speed Brake Booster, Master Cylinder Kit.pdf
      Bob.
      TuoCo, CA
      Quote Originally Posted by a67 View Post
      Bob.
      Weird that they sell the brackets but not the seal or the seal plate...
      Steve
      Check it Out Here
      Apr 2015
      Thanks for the help, I contacted DSE and they do sell them separately. You just have to call and tell them what you are looking for. About $30 for both pieces, plate and rubber boot/seal.
      TuoCo, CA
      Awesome. Thanks.
      Steve
      Check it Out Here
      May 2009
      Quote Originally Posted by Cunning69 View Post
      do you have any pictures on the plate ?
      Oct 2008
      Toronto, Canada
      Name:  Booster seal and plate.jpg
      Santa Barbara, Ca
      So it looks like the parts DSE sells still work with the Tuff Stuff booster? Any info on compatible master cylinders?
      Andy
      1967 Camaro RS
      Magnacharged LS1/T56
      543 rwhp, 516 rwtq
      Sold
      1968 Firebird
      LS427/570 and T56 Magnum
