    Results 1 to 10 of 10
      Jan 2013
      ST George UT
      1967 Chevelle Project
      No longer a project. It is complete and running and driving. Just added all new coil overs and tubular suspension all the way around.
      I have a very clean 1967 Chevelle SS big block clone.
      It has all original sheet metal. No rust.
      It is 100% SS clone.
      Factory SS gauges.
      Factory SS center console, Auto.
      Car was painted about 5 years ago. At that time all new seals, felts were installed. New or redone stainless, bumpers, lights, grill bezels also installed.
      Headliner was new a couple years ago and in great shape, black
      Door panels are also new.
      Factory floor shifter with factory style console.
      Everything in and on the dash is new and great working order.
      -New carpet kit
      -New SS dash
      -New power disc brakes
      -New AGR close ratio power steering box
      -All new steering tie rods, idler arms
      -New tubular upper & lower control arms
      -new front reclining seats
      -all new glass except rear window
      -new kick panel with speakers
      -new carpet sail plates
      -new SS steering wheel
      71 big block 402
      -new MSD HEI distributor
      -new water pump
      -new t-stat and housing
      -new engine mounts
      -new oil pan and gasket
      -new fuel pump and gasket
      -new freeze plugs
      -new intake gasket
      -new alternator
      -new coated headers
      -new flex plate
      -rebuilt auto trans
      -new 15" rally wheels and BFG tires.
      -new air cleaner
      The engine is a big block chevy engine. It is complete and runs great. It is a 1971 402 big block.
      Motor was pulled, cleaned, new gaskets, new g.m oil pan, re painted and installed. New tune up, motor mounts, belts and hoses.
      Transmission is a rebuilt Turbo 350
      Dual flow master exhaust.
      The wheel in the pictures of paint were just used for rolling around. It now has brand new 15" rally wheels and brand new BFG tires.
      SOLD
      Clean CA title. Black plates.
      Very, very clean body and paint.
      Location is San Jose CA
      Might do part trade for 1997-2008 silver ado, sierra for my sun, must be x-cab and 4x4. You will need cash on your end.
      Jan 2013
      ST George UT
      SOLD
      Just installed new AGR steering box and all new steering.
      New tubular upper and lower control arms.
      New black carpet kit.
      I have a complete Tremec 5 speed change over for the car for extra.$
      Jan 2013
      ST George UT
      Pictures
      Thanks for all the request for interior and other pictures.
      Car is complete and running. Some of the pictures are during restoration.
      Jan 2013
      ST George UT
      She is up and running .
      May do part trade for Silverado 4x4 for my son
      Jan 2013
      ST George UT
      Pictures
      Current pictures today
      Jan 2013
      ST George UT
      Finally sunny weather.
      Just installed new
      -QA1 coil over kit for the front.
      -Hotchkis sway bar for the front.
      -1" lowering springs for the rear.
      -Upper and lower tubular 4 link bars in the rear.
      -New Beltech shocks for the rear.
      -New stock floor shifter and factory SS console.
      Jan 2013
      ST George UT
      Current pictures.
      Feb 2019
      Can we see some undercarriage and suspension shots?
      Jan 2013
      ST George UT
      Yes
      It is no longer a project. Everything works as designed. It now has 108 miles on the car. Turn key ready to go.
      I also raised the front end up with the coil overs about 1" since those pictures. All lights, gauges, horn, dome light, glove box light, heater, console light, console clock, everything works as designed.
      Only thing not working as designed at this time is the reverse lights..
      Jan 2013
      ST George UT
      Sold
