Results 1 to 20 of 32
02-12-2019 #1Registered User
- Feb 2019
- 55
Hotchkis subframe and rear for 67 camaro
Hello,
I have a 67 camaro roller, and am swapping in a LS3/Tremec TR 6060 and I need to choose a subframe and rear end. Leaning towards Hotchkis with adjustable fox shocks, subframe connectors and Currie 9” rear end with 3:50 Posi Trac. Any opinions on this set up? I know this will drop the the car by 2”. I want to keep the weight down and want the RPM to be low on the highway. I know typical 9” rear ends are much heavier than the 10 bolt but I heard Currie’s are decent for weight and strong. I also know there are more advanced subframes with coil overs and infinite adjustability but I heard the Hotchkis package fits well and is a solid performer on the autocross. The shocks allow a comfortable ride but can be adjusted for the curves. Using Wilwood brakes- 6 piston front/4 piston rear. Any opinions on the Hotchkis subframe and fox shocks would be appreciated. Also, I can’t find anyone who provides a transmission crossmember for a TR6060—-may be easy enough for me to fabricate. Thanks.
Chris.
