    Results 1 to 12 of 12
      Jan 2010
      Pine Plains, NY
      Detroit Speed subframe and frame connectors options not to weld them
      Hey folks - I really don’t want to weld my subframe connectors to my subframe. I think I read that someone used bushing and bolts? Any pointers ?
      thanks in advance
      Mountain Springs, Texas
      Pic of some nice custom brackets here:
      https://lateral-g.net/forums/showthr...ight=Ironworks
      Don
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Feb 2018
      Southern IN
      I've got the DSE sub and connectors and welded the DSE brackets to the subframe and drilled/bolted them to the connectors. Before doing that, I drilled the connectors out and welded in 1/2" I.D. tubing to keep the frame connectors from crushing. Looks sanitary and works beautifully. I can post some pics if you need but lots of folks have done it this way so I'm sure there's pics floating around.
      Shane
      #theanchorholds
      68 Camaro build thread:
      http://lateral-g.net/forums/showthread.php?t=56387
      Jan 2010
      Pine Plains, NY
      These are beautiful - I emailed Iron works to see if they can help out
      Jan 2010
      Pine Plains, NY
      Thank you @gmachine1911 - I wouldn’t mind seeing the pictures and if you could email me with any helpful info setting this up that would be great !
      Oct 2018
      San Jose, CA
      They will work better if welded - more like the way modern car frames are built.
      1971 Camaro - 406 / T56
      2016 Camaro SS convertible
      2018 Colorado 4x4
      Aug 2015
      Fremont, CA
      I'm diggin' these brackets.
      Feb 2018
      Southern IN
      Here's the way I did it. Nothing that hasn't been done before...What you can't see is that I reinforced the subframe connectors where the bolt holes were drilled by welding in 1/2" I.D. tubing into the frame connectors to keep the from collapsing. A person could have plug welded the connector brackets to the connectors but if you ever have to get the subframe out of the car, it'll be a huge pain.
      Shane
      #theanchorholds
      Oct 2018
      San Jose, CA
      Nah. Grinder will go thru the welds. How often do you replace the subframe ? Mine has been in place for almost 40 years now.
      2018 Colorado 4x4
      Beach Park IL
      I have had 3 different motors in my 2nd gen in the past 24 months and have never taken the hood off, drop the subframe every time. It is the best part about having a subframe car.
      I prefer the method shown above, simple, easy, solid. Done.
      Donny
      Nov 2010
      Ventura County CA
      For the spacer tubes, do you tack weld them from the inside of the tubing or are you somehow rosette welding them on the outside?
      Feb 2018
      Southern IN
      Quote Originally Posted by TheBandit View Post
      Yes...both. 😀
      Shane
      #theanchorholds
