    Results 1 to 20 of 37
      Jun 2014
      braintree essex england
      Country Flag: UK
      T56 magnum transmission
      hello all i have a T56 magnum transmission just wondering which oil you all use . cheers kev
      Quote Originally Posted by KEV 190164 View Post
      What does Tremec recommend? They used to recommend ATF in the older T56 transmissions. I run Amzoil ATF in mine, but I do not have the carbon blocker rings that the Magnum uses. You can also see what is called for in newer cars that use the TR6060, which is what the T56 Magnum is.
      Instagram @projectgattago
      Dr. EFI
      Arizona
      Straight off the Tremec Website.
      Q: What type of fluid does TREMEC recommended?
      A: For all TKO 5-speed models, TREMEC recommends GM Synchromesh™ (GM Part # 88861800) – or equivalent, or Mobil 1 Synthetic ATF. For all other aftermarket models we recommend Dexron III ATF
      Jan 2014
      Portsmouth NH
      I 2nd oleyeller. I have been using the Mobil 1 Syn ATF and all has been well.
      Feb 2016
      Texas
      I called Tremec and they recommended ATF so I use Mobil 1 ATF in my T56 Magnum.
      Oct 2018
      San Jose, CA
      Really ? I just got one from Bowler and the tag says use gm synchromesh or the royal purple MTL. Is that really atf? I didn’t think so.
      1971 Camaro - 406 / T56
      2016 Camaro SS convertible
      2018 Colorado 4x4
      Pensacola, FL
      I spoke directly to tremec to discuss this, and they prefer any brand dexron III ATF. Specifically said brand does not matter. And it was suggested to use non synthetic, but that synthetic would be ok. I wanted to use the best oil I could buy, and they still suggested plain old dexron III
      Oct 2018
      San Jose, CA
      hmm.. Below is the tag Bowler ships with the Magnum these days. Just got this a week ago.
      Calls for Synchromesh, which seems is thicker than DextronIII but thinner than 75W90 gear oil. Synthetic blend.
      https://www.acdelco.com/auto-parts/v...ion-fluid.html
      yet spec sheet clearly shows DexIII and sounds like that's also what Tremec is still recommending per your recent inquiry.
      http://www.tremec.com/anexos/TREMEC_TR-6060_1017.pdf
      Curious..
      2018 Colorado 4x4
      Oct 2018
      San Jose, CA
      Got input from Bowler. They say you can use either one just don’t use gear oil. Tremec is also selling their own fluid now which is not exactly ATF either.
      Anyway - Bowler says they like the Synchromesh best so that’s why they recommend it.
      2018 Colorado 4x4
      Apr 2012
      Woodstock, IL
      Been using GM or Pennzoil Synchromesh on everything, seems to be holding up great.
      -Dale
      SchwartzPerformance
      Feb 2016
      Lawrenceville, IL
      We've used Royal Purple Synchromax and Driven Brands Synchromesh for several years now with absolutely no issues. We recently just refreshed a T56 Magnum that had been raced for 5 years on Royal Purple and it still looked new inside......
      visit us on the web at www.bowlertransmissions.com
      Jun 2014
      Country Flag: UK
      i looked through an old message i got from dale from schwartz when i bought the t56 from you he recomended gm synchromesh so thats what i used
      Aug 2015
      NJ
      I was told 2 things. First off I was told to use Pennzoil syncromesh which is fine for normal driving and a moderate build making decent hp and tq. When I said I was 742HP and 689 TQ, he said I was better off with a high temp atf. I then asked about Redline hi-temp atf(snythetic). He said that it may be too slippery for the clutches. So what is a suitable option?
      I've read in the past where Royal Purple is NOT recommended and now it is - I am confused
      '68 Chevy Camaro Pro-tour ~ project DMENTD
      '57 Chevy 3100 Pro-tour pickup ~ under construction
      Houston, TX
      Quote Originally Posted by pittpens24 View Post
      ...I then asked about Redline hi-temp atf(snythetic). He said that it may be too slippery for the clutches. So what is a suitable option?
      the tech maybe confused with auto transmission. I've heard similar stories about synthetic atf in autos. However, I don't think it doesn't hurt to use in manuals (there are no clutches inside the manual trans that I know of). I ran Walmart ATF in my TR6060 (bought it used) for awhile, then switched to Redline D4. The shifts are much smoother with the Redline fluid.
      Tu Ho
      Firebird V2-LS swap
      I don't have synchronizer gears in my T56 ;-)
      Dr. EFI
      Feb 2016
      Lawrenceville, IL
      We've always had the best luck with the Synthetic fluids in the Magnums. I've talked to guys who've used every brand out there and I honestly do not think that you can go wrong with any of them. I've yet to see any particular fluid cause a problem as long as it is an ATF or Synchromesh fluid going in. Like a lot of things, I think the good and bad stuff you hear about the fluids is based on personal brand preference. Like saying all Fords are junk because I like Chevys.
      Jun 2006
      Quote Originally Posted by rickpaw View Post
      The synchro design has friction surfaces, the fluid you use will change the behavior of the surface interaction between the synchro pieces.
      Jun 2010
      Deployed
      I use royal purple synchromax. It’s ATF designed for manual gearboxes.
      1970 Camaro/DSE build
      Aug 2005
      Hamilton, NJ
      Quote Originally Posted by Craig@Bowler View Post
      Same recommendation for a regular t56? 4th gen, etc.
      Scott from NJ.
      Vent Windows Forever! ...
      Houston, TX
      Quote Originally Posted by 68Cuda440 View Post
      Didn't know that. Learn something new everyday.
      Tu Ho
      Firebird V2-LS swap
