    Page 2 of 2 FirstFirst 1 2
    Results 21 to 37 of 37
    1. #21
      Feb 2016
      Lawrenceville, IL
      Quote Originally Posted by BonzoHansen View Post
      Same recommendation for a regular t56? 4th gen, etc.
      You can definitely use it in those older units as well. We even use it in the TKO and T5 transmissions as well. It has worked well for all of them.
      visit us on the web at www.bowlertransmissions.com
    2. #22
      Sep 2016
      LA - Lower Alabama
      Quote Originally Posted by 68Cuda440 View Post
      The synchro design has friction surfaces, the fluid you use will change the behavior of the surface interaction between the synchro pieces.
      I don't have a lot of experience with the T56, but this is in line with my theory on why some people see so much difference going from one fluid to another. The combination of the synchro design with the large rotating mass of the Magnum really exaggerates the "feel" you get when shifting into some of the gears. Combine that with different shifting styles, and it's really not surprising that a change in the fluid properties affects the shift feel noticeably from one person to the next.
      Dude are you made of leprechauns? Cause that was awesome!
    3. #23
      Jun 2010
      Deployed
      Maybe we complicate this discussion with 3rd party opinions. TREMEC provides a spec, I simply matched that spec to the fluid I use. TREMEC reccomends “Dexron III ATF”. Only the TKOs do they reccommend synchromesh. Royal Purple Synchromax meets DEX III specs.
      Putting gear oil in a T56 is not something I would do....
      1970 Camaro/DSE build
    4. #24
      NJ
      Agreed. Just got mine this week, think I'll go with what Craig suggests. Royal Purple for me!
    5. #25
      NJ
      Just to add more fuel to the fire, I was over a friend's house helping him get his car back together and I see he purchased this for his Magnum...
    6. #26
      Jun 2010
      Deployed
      What does the fluid mimic? Gear oil or ATF? Just marketing oil IMHO for the distributor and Tremec to cash in on another product that’s likely made by valvoline etc. my RP synchromax has served me well for the last 5 or so years.
      Quote Originally Posted by John McIntire View Post
    7. #27
      Oct 2007
      Well does it depend on the age of the trans? I used Dextron 2 was going to run it for 5k miles it hasn't been run yet..
      67 Camaro In progress
    8. #28
      NJ
      My buddy said that the guy on the phone said that is the number one question they get over everything else. "What fluid do I run in it?" So they came up with their own. I'm sure it's made by someone, Castrol, Mobil 1, who knows. There was no info on the containers or the box they came in. I bet they just wanted to make some money off of all us that just don't know what to run in our Magnums. I guess if you run their stuff, you'll have absolutely no warranty issues!
    9. #29
      Sep 2016
      Bakersfield, CA
      I plan on using the Tremec oil that comes with my T56 Magnum when I install it. But after 500 miles, I may go with the Redline D4: https://www.redlineoil.com/d4-atf
      I'm thinking about buying one of those oil testing kits and sending off a fresh sample of the Tremec fluid and the Redline to compare them.
      http://www.TheFOAT.com/92GTA
      1969 Pontiac Firebird
      w/535ci IAII aluminum block, Dailey dry sump, Holley EFI (full road race build). Primer black w/black interior.
    10. #30
      Jun 2010
      Deployed
      Quote Originally Posted by anguilla1980 View Post
      That’s just money down the tubes. RP synchromax, Tremec fluid, redline...im confident you don’t see a difference. The T56 and the Magnum have been around for a while...long before Tremec has their own fluid and we have been beating on these transmissions.
    11. #31
      Sep 2016
      Bakersfield, CA
      I'm not sure what you are saying here. Are you saying it's a waste to change the oil at 500 miles? Because I'm being instructed to do that by the vendor.
      Or do you think the Redline costs a lot more than just refilling it with the Tremec fluid, because they are about the same.
    12. #32
      Jun 2010
      Deployed
      To spend money on oil analysis. To prove what we already know...any properly spec’d fluid will work in the magnum.
    13. #33
      Sep 2016
      Bakersfield, CA
      Ah, gotcha. Not like it's a lot of $$ and I'm honestly curious what is in Tremec's fluid as it's new and no one seems to know who the OEM is. Dave@Redline did tell me yesterday it's closer to a 75W85 type oil like the Gen V Viper T56 trans uses than just an ATF Dex III like they have recommended in the past.
      I'm particularly looking forward to seeing how the Tremec fluid shifts in the winter compared to the Redline as well. Should be mid-December when I hit 500 miles on the new trans and need to do the fluid change.
    14. #34
      Jun 2010
      Deployed
      Will it tell you make up? I thought they only gave metal break downs.
    15. #35
      Jonesboro, Arkansas
      Quote Originally Posted by Craig@Bowler View Post
      We've always had the best luck with the Synthetic fluids in the Magnums. I've talked to guys who've used every brand out there and I honestly do not think that you can go wrong with any of them. I've yet to see any particular fluid cause a problem as long as it is an ATF or Synchromesh fluid going in. Like a lot of things, I think the good and bad stuff you hear about the fluids is based on personal brand preference. Like saying all Fords are junk because I like Chevys.
      I'm thinking people are overthinking this topic. Read the above quote and use accordingly.
      Carl Wilson
    16. #36
      Oct 2018
      San Jose, CA
      Craig speaks the truth in my book.
      1971 Camaro - 406 / T56
      2016 Camaro SS convertible
      2018 Colorado 4x4
    17. #37
      Nov 2014
      SoCal
      Thank you very much for the fantastic news Larry Callahan.
