    Page 4 of 16 FirstFirst 1 2 3 4 5 6 7 8 9 14 ... LastLast
    Results 61 to 80 of 312
    1. #61
      Jul 2017
      It’s a Mobile 1 gm is using now. My brother sent me this link and said it was this one. https://www.thelubricantstore.com/mo...SABEgL7SvD_BwE
    2. #62
      Jan 2019
      Quote Originally Posted by jasonz28camaro View Post
      Confirmed!
      https://www.corvetteactioncenter.com...rint-1398.html
    3. #63
      Jan 2019
      LT4 Holley 302-20 oil pan oil cooler adapter how to guide.
      If your using the LT4/LT1 oil pan and need to run an oil cooler it is easy to do. Besides the AN fittings and hose, you need the Earl's 1129 diverter adapter.
      In this picture you'll see the stock Holley flow through billet cap.
      There are 2 sensor inputs if you decide to use them.
      When done you will need the correct AN fittings to connect to your oil cooler. More to come.
    4. #64
      Jan 2019
      Had a few hours yesterday evening and decided to start fitting a few of the easier patch panels. I got the drivers side cowl panels fitted and the lower front fender mount area that was rusted through. It is nice having had the car baked and all the rust removed. Sure speeds this process up.
    5. #65
      Jan 2019
      I thought I would show you guys how well the Eastwood fast etch rust remover works.
    6. #66
      That's amazing!
      Instagram @projectgattago
      Dr. EFI
    7. #67
      Jul 2018
Size:  219.8 KBI'm doing a very similar build. 69 camaro with LT4 and 8L90
    8. #68
      Jan 2019
      Quote Originally Posted by TallTex View Post
      You don't have any pictures in your build thread. I need to hear more about your build. Is it running yet?
    9. #69
      Jul 2018
      It is not running yet. Bolting things on for the last time. Just firewall jammed. But it's making a lot of progress now and getting exciting. TCI pro tour clip. TCI torque arm with Currie 9" rear. TMI interior started. Just decided to go with flush glass and paint and shorten/tuck the bumpers.
    10. #70
      Jan 2019
      What did you do for breaks? What TMI interior? The firewall is a bit agonizing. Where did you mount the huge ECU box, and trans control box?
    11. #71
      Jul 2018
      I got 12" Wilwood set along with currie rear and ididit steering all from TCI.
      Sport R interior with red stitching from TMI. The console is the hard part. I want the matching console
      But with the transmission tunnel now 40% larger I will probably have to get one made. TCI products are great but they don't even offer dimensions of their consoles and have been unhelpful and indifferent when talking to them. Glad I did the smooth firewall. I didn't get the connect and cruise. Long story with a great buy. But the LT4 is a new crate motor. The wiring harness should be here in a couple of weeks and ECU placement will be figured out
    12. #72
      NJ
      Please post pics when you get your AutoRad setup!
    13. #73
      Jan 2019
      So I take it that with the TCI front clip the transmission is sitting higher than with the SPEC chassis I'm using. 40% seems like a lot. If you need dimensions on the console try calling Canada Seat Skins USA Store. They seem to be very helpful and are a big TMI dealer I think.
      If you didn't get the Connect and Cruise package that does create a few challenges. ECU placement is the tricky part.
      - - - Updated - - -
      Quote Originally Posted by John McIntire View Post
      I will get it at the end of the month. Pictures will be posted 😎
    14. #74
      Jan 2019
      Put the B&M transmission dipstick on today. Took about 3 minutes... lol it is a flexible SS line, so mounting location will be easier.
    15. #75
      Jan 2019
      So since the firewall was so banged up I decided to just replace it instead of trying to patch it. Got the new AMD panel with heater core delete. Test fitting it to the chassis there are a few spots that rub. All easy to fab and fit. This car will have no corners cut and no expense spared to make it perfect.
    16. #76
      Sep 2017
      Looking great!
      1965 Buick Skylark Sport Coupe V8, Two Door Hardtop - Project
      2014 Mercedes Benz C300 Sport 4Matic - Daily
    17. #77
      Jul 2018
      The tunnel needing to be made larger than you had to would actually indicate my car body is sitting lower
      Than yours I guess. After the vintage air was put low behind the dash we think we still have room for the ECU either behind the dash or under the custom console that will be made
    18. #78
      Jan 2019
      Do you know what your body clearance will be from the ground? My engine and transmission are sitting very low in the car. I think from the ground to the frame I end up around 5" and the transmission pan is around 4"-5" ground clearance.with the Holley 302-20 oil pan I only have about 1/2" clearance from the rack and pinion unit and cross support. I think I will only need to adjust the tunnel up about 3/4" to clear everything with room to spare. Fingers crossed....
    19. #79
      Jan 2019
      Guess what Size, Brand Model.....Hint: shoe size is 11
    20. #80
      345?
      Dr. EFI
