    Page 13 of 16 FirstFirst ... 3 8 9 10 11 12 13 14 15 16 LastLast
    Results 241 to 260 of 312
    1. #241
      Jan 2019
      That would have been nice for sure! I do like making it my own thou.
      Got it fitted to the SPEC Chassis and all the final planning done yesterday. Should be wrapped up and ready for epoxy primer in a few weeks.
      A huge thanks and shout out to Roadster Shop (Phil) for an awesome chassis setup and great customer service throughout this build.
      Also thanks to Paul and Steve a Barr's Classic Auto Restoration in NC for the excellent work fitting and gapping the sheet metal.
      Also a note on the shifter mentioned a few potst up. It can be removed from the big ugly base it comes in by tapping out the pin on the the one end. You end up with a nice compact unit to work with.
    2. #242
      Jan 2019
      Started the bodywork on the hood. The hood vents are looking crisp! Also made a custom mount t for the transmission controller and under hood fuse box.
    3. #243
      Jan 2019
      Did the guage and AC vent layout for the Dakota digital setup and laid out the lights, washer switch and AC control faceplate. Now I just need to cut them out on the laser and start test fitting.
    4. #244
      I love the way the hood came out. Nice job on the bracket.
    5. #245
      NJ
      Looking good, happy to see some updates!
    6. #246
      Dec 2011
      Planit Oahu, Hawaii if you don't belive me check shipping prices
      so is this going to be your boys 1st car?
    7. #247
      Jan 2019
      Quote Originally Posted by FlyDoc View Post
      No way lol. We are building a 66 C10 for him now. It's also a frame off but much simpler.
    8. #248
      Jan 2019
      Thanks. I cut out some of the custom dash parts a few days ago. I need to refine the letters a bit, but close.
    9. #249
      They look good already, 👍
    10. #250
      Jan 2019
      So the Anvil auto side marker lights are a direct fit on the 69 Camaro, but I wanted to move the marker lights factory location and give them a reassessed look. Got the tabs welded in.
      Also got the doors fitted ant primed.
    11. #251
      Jan 2019
      Making more progress. All the loose panels are ready for paint. The main body gets blasted roof skin attached tomorrow and epoxy applied. The hood underside is done in satin black as well as the front fenders. The underside of the hood with the vents looks factory!!
    12. #252
      Jan 2019
      Making good progress. Body shell has the epoxy. Now the detal work begins.
    13. #253
      Sweet! it's getting exciting now!!
    14. #254
      Jan 2019
      I haven't had time to run by the paint booth to see how it looks. Is should be done tomorrow. And assembly will start. Won't have the interior until December it looks like. But I will have it assembled and at least get it running before the interior shows up.
    15. #255
      Jul 2019
      Ohio
      Quick Question - Did you end up having to relocate the DS knock sensor with the ultimate headers and if so where did you move it too?
      Also would like to learn / reapply where you ended up putting the ECM and fuse box for my build
    16. #256
      Jan 2019
      Quote Originally Posted by srode View Post
      I don't remember relocating it, but I will check. I faxed a bracket and mounted the ECM under the dash and put the fuse box in the front with the transmission controller. I think I posted pictures if you scroll back a bit.
    17. #257
      Jan 2019
      I did not need to relocate it.
    18. #258
      Jul 2019
      Ohio
      Quote Originally Posted by GPRaceWorks View Post
      Thanks! The Speedtech Extreme frame headers require relocating, thought I would reapply if you did.
    19. #259
      Jan 2019
      Making a bit more progress. Body didn't go to paint yet, but all the panels are done. Thought it would be best to get the RestoMod AC test fitted first. Should be delivered today after a 12 week wait.
      The wheels will be here next week. Never thought I would see this project getting so close to completion after all this time.
    20. #260
      Hood looks great!
