Results 221 to 240 of 312
06-16-2020 #221Registered User
- Mar 2019
- 4
The setup is nice but I agree, a little instruction would be good.
I called last week about the spacer between the support and frame and it depends on how your fenders line up. Jim(autorad) said to mount the support to the fenders and adjust your gap to the door and see if you need the spacer.
The radiator will need to go on after you mount the hood latch center support because there is no access to hold the allen head screw to tighten the nut for the support. Just a assembly/sequencing issue.
Also mine came with the intercooler fittings on the passenger side which would require longer hoses across the front. I sent it back and they relocated them to the driver side to minimize hose length and potentially added fittings.
Looking forward to seeing your build continue!
