    Results 1 to 8 of 8
      Sep 2018
      Sandy OR
      Wilwood Brakes not fitting DSE spindle
      Installing Wilwood Front Brake kit 140-8922 on my 68 Camaro with a DSE subframe. The calipers do not fit over the rotor, forget centering. Wilwood provides shims for in between the spindles and the caliper mounting brackets, they suggest starting with one .029" shim. After doing that and not being able to get the caliper on I took it apart and installed four shims, just under an 1/8", calipers still not fitting. Looks like they are missing by an additional 1/8". Two questions;
      1) Has anyone experienced this?
      2) If not who you call first? DSE or Wilwood?
      Thanks, Will
      Louisville, KY
      Pictures of the misalignment? Are you trying to shim the caliper bracket with pads installed?
      Do you have the caliper bracket facing the right way?
      Andrew Scott
      '87 GN - 12.8 @ 108
      https://www.andrewdscott.com
      Instagram: @andrewdscott12
      Twitter: @Andrew1427
      Sep 2018
      Sandy OR
      Without pads. Yes caliper bracket is facing correct direction.
      Sep 2018
      Sandy OR
      Well it must have been late last night. Took it apart this morning and then discovered the 1/4" aluminum spacer on the hub (removed and hanging off stud for picture. Everything lines up as expected with a single .029" shim. I am assuming the spacer is to allow attaching wheels and checking clearances prior to installing brakes. I will double check with DSE unless someone can confirm? Thanks for listening.....
      Louisville, KY
      Good find!
      Andrew Scott
      '87 GN - 12.8 @ 108
      Jun 2010
      Deployed
      That spacer came with the DSE frame? I don't recall having one of those and my BAER brakes installed without a hitch. Direct bolt on like they were made for each other.
      1970 Camaro/DSE build
      Feb 2011
      dallas, tx
      Yup no spacer here as well
      Sep 2018
      Sandy OR
      OK got the definitive answer. It did not come from DSE but from the builder that installed my suspension. With the spacer removed the Wilwood kit fit great. Thanks for all the responses.
