    Results 1 to 7 of 7
      Nov 2007
      Windsor, Ontario
      69 Camaro engine control harness installation location.
      Ok guys I'm at the point of starting the wiring and looking for advice on where to mount things.
      I have the vintage air installed so space under the dash is tight. The AC lines run up between the fender and the wheel tub through were the blower motor was. Also have the dash modified to accept a double din radio where the ash tray was. Plans also involve a console at some point.
      I did install a grommet in the tunnel up close to the firewall (saw this on some DSE builds) in anticipation of future wiring.
      Any tips on where to install the ECM and associated fuse box?
      I have a feeling that I'm going to be loosing my glove box.
      Will I need to add another access through the firewall, and if so where's a good location?
      Sep 2016
      LA - Lower Alabama
      Depends on the ECM. I'm running the Holley Dominator ECM and it fit under my passenger seat. It's tight, and it's a pain to connect the USB cable, but it's out of the way and not taking up real estate behind my dash.
      Dude are you made of leprechauns? Cause that was awesome!
      Nov 2007
      Windsor, Ontario
      I have the GM ECU and the harness that I purchased with the crate motor
      Aug 2010
      Los Angeles
      I'm using a gen 5 console and hid it under the front portion of the console under the dash. Works great and easy access to the port for upgrades or tuning.
      Sep 2016
      LA - Lower Alabama
      Quote Originally Posted by AB69Z View Post
      If I remember correctly, those are pretty tall, so it may not fit under the passenger seat.
      They fit nicely on the passenger side inner fender.
      John Parsons
      I mounted the fuse block to the core support where the battery was and made a bracket that mounts the ECM up under the passenger fender adjacent to the fuse block. Battery is in the trunk.
