    Results 41 to 60 of 69
    1. #41
      Apr 2007
      Greeley, CO
      Love the color of your car! Just got my wheels and tires today. 18x9 5.5bs for all 4. 275/40/18 tires. I am also impressed with what I've seen so far. As soon as I have some decent weather I will get them mounted and share a pic!Name:  20190212_160829.jpg
Size:  145.9 KBAttachment 161442
      Matt H.
    2. #42
      Oct 2018
      San Jose, CA
      26lbs for the 18x10 6” bs wheel
      1971 Camaro - 406 / T56
      2016 Camaro SS convertible
      2018 Colorado 4x4
    3. #43
      Feb 2017
      Bowling Green, KY
      Quote Originally Posted by 2yellow69 View Post
      Great! Thank you very much!
    4. #44
      Oct 2018
      San Jose, CA
      A few photos - got tires mounted and mocked up on car. 18x10, 6" bs all around. 275/295 NT05 tires. Fit is great from what I can tell.
      I have 3/8" clearance to the seatbelt hump and 1/2" to the spring in back with no spacer. I could go as low as needed with this set up - maybe hammer in the seat-belt hump just a bit. But current suspension set-up the car isn't ultra low - hotchkis springs set-up. So plenty of fender clearance in the back. I'll run 1/4" spacers in the back for now - will re-evaluate when I redo the rear suspension and add a 9" rear. I have a 4th gen 10 bolt which is .75" wider than factory second gen - which works out better for these wheels since there is more brake caliper clearance on a 6" bs vs. a 5" bs and there is no 5.5" bs option. So when I go 9" I will just use the 4th gen dimensions which should work out great. Don't plan to mini-tub the car. 295's seem plenty wide enough to me. I do wish more companies made them. And I could fit 315's with some minor massage work on the seat belt hump area especially once I move to a coil over spring - worse case some gentle fender lip rolling if I needed to keep the .25" spacers in there to make them work. Pretty sure a 315 will work down the road - especially on a 10" wheel. Not the ideal wheel width for a 315 but it would work OK if I want to switch to a tire that doesn't have a 295.
      2018 Colorado 4x4
    5. #45
      May 2011
      Chippewa Falls, WI
      Quote Originally Posted by c4racer2 View Post
      Looks good, and seems to fill the wheel well nicely! I would only recommend a 315 for a 10.5 and wider rim. 11 is ideal for a 315 tire width. Generally a stretched tire will perform better than a even or pinched setup for handling or autocross. If its is purely for looks/widest tire and you are not concerned about every ounce of performance then it can be done on less than a 10.5.
      Justin N.
      1966 Chevelle
      1992 GMC Typhoon
      1989 Jeep Wrangler CJ 6.0 Twin Turbo
      1981 Jeep CJ7
    6. #46
      Oct 2018
      San Jose, CA
      295 is a good size for this car w/o going to mini tubs - which is a lot of work and beyond the scope of what I want to do.
      I just wish there were more of the 200TW tires in this size. Nitto and Yokohama seem to be the only ones. There are a few 285 options - but most are jumping from 275 to 315. I can always switch to 11" wheels if I go that route, these are also available in 18x11 with 6" bs.
      We shall see how these do and it will be a few years before I need to change them anyway - hopefully by then I'll have the rear suspension done too.
      2018 Colorado 4x4
    7. #47
      Apr 2007
      Greeley, CO
      Finally weighed mine. 25 lbs for an 18x9 5.5bs no center cap. 275/40/18 Sumitomo HTR Z III is 28.5 lbs. Sumitomo says it should weigh 31 lbs.
      Matt H.
    8. #48
      Apr 2007
      Greeley, CO
      finally got the tires mounted.Name:  20190301_164503[1].jpg
Size:  171.7 KBName:  20190301_162037[1].jpg
Size:  140.6 KBName:  20190301_162015[1].jpg
      Matt H.
    9. #49
      Oct 2018
      San Jose, CA
      Oh ya ! looks killer !
      2018 Colorado 4x4
    10. #50
      Apr 2007
      Greeley, CO
      Thanks! I appreciate it!
      I have to say Thank You to Rocket Racing Wheels. I was certainly a little stressed about the wheel situation. Cheap wheels weren't going to cut it and a lot of them wouldn't clear the new brakes. High end wheels are out of my price range. The wheels in my price range just didn't have "The Look" I was after. It's been 10 years since I pulled this car into the garage and let it snowball on me!!! Rocket Racing has solved a major issue for a lot of car builders by releasing these wheels at a decent price point. I might actually be able to get my Camaro on the road by this summer!
      Matt H.
    11. #51
      Oct 2012
      What front brakes do you have? Also, what size rotors? Thanks
    12. #52
      Apr 2007
      Greeley, CO
      Front brake calipers are stock C5 Corvette. I think the rotors are 13". The problem I was having with wheel fitment was the wheel contacting the caliper abutment. Rear brakes are 2015 Camaro V6.
      Matt H.
    13. #53
      Lawrenceburg, TN
      Oct 2012
      I noticed that issue with abutment also. How much extra clearance do you have from outside of caliper to wheel? I have Kore3 c5 rotor brackets but if possible I would like to install Z51 or c6 z06 rotors, I figure the cost is almost the same why not fill up the wheels. Really considering a set of these in 18s. Are yours 7 or 8" width?
    15. #55
      Apr 2007
      Greeley, CO
Size:  160.1 KBName:  20190306_134252[1].jpg
Size:  129.3 KBName:  20190306_134222[1].jpg
Size:  90.2 KBName:  20190306_134351[1].jpg
      Sorry some of the pictures are not orientated correctly. It depends on how I held my phone on how the pic seems to upload.
      It's hard to tell but there is a LOT of room in there. The two middle pics show the inside profile of the wheel pretty good. I did the best I could contorted under the car!!
      My setup is this: original ATS tall spindles
      C5 brakes
      18x9 wheels with 5.5 bs
      Matt H.
    16. #56
      Oct 2012
      C5 brakes
      Thanks for the pics! Above and beyond. Looks to me like these wheels should clear the 14" rotors and c5/6 base calipers without problems. Also, what was involved in the rear camaro v6 brake conversion?
    17. #57
      Apr 2007
      Greeley, CO
      Again with the sideways pic.
      I can't take credit for anything with the rear brakes except for finding the guy to pay for the whole kit! And I installed it, so there is that.
      I'm just glad I found a way to use GM brakes on a 9".
      He's not a forum supporter so I don't want to rile anyone up so I'll send you a PM with his info.
      Matt H.
    18. #58
      Jan 2018
      Oregon
Size:  140.3 KBName:  8A2DD586-5B8A-427C-8D71-05450EB34706.jpg
      Here is what the clearance looks like with c6 z06 rotors. Unfortunately I don’t have calipers yet but there is still plenty of room.
      Not sure why the second pic is sideways, sorry for that.
    19. #59
      Oct 2018
      San Jose, CA
      Here are 14” rotors in the 18” wheel.
      2018 Colorado 4x4
    20. #60
      Oct 2018
      San Jose, CA
      The wheels clear the ST60 calipers easily.
      2018 Colorado 4x4
