      Nov 2015
      The Netherlands Groenlo
      Country Flag: Netherlands
      68 Camaro Richmond 4+1 street speed question
      Hello,
      Can i use the richmond 4+1 street speed under my 68 camaro without
      any modification ?
      Which crossmember and transmission mouth i have to use?
      Here a link of the transmission
      https://www.summitracing.com/parts/rmg-7021710a
      Im planning not to use the middle console
      Any suggestion is welcome
      Thanks Maylon
      Ontario, Canada
      I can't comment on how well it fits, but my research has found that a TH400 cross member will work.
      Ken
      My other car is a Vega.
      I swapped on into a '69 Camaro and I used the TH350 crossmember and slid it back so that the front bolt hole in the crossmsmber lined up with the rear hole in the frame. Then drilled holes for the rear holes of the crossmember into the frame.
      Northwestern NJ
      May I ask why you want to use it? It's not an overdrive transmission...
      Tommy
      Tommy Souren
      "The older I get, the faster I was."
      Grandma's 20k mile '80 Malibu Classic, in-progress factory style LS6 454, Legend LGT 700 5 speed, 9" 3.70 posi, Global West suspension, 12"/11" discs.
      Nov 2015
      Quote Originally Posted by Kenova View Post
      Ken
      Thank you Ken
      - - - Updated - - -
      Quote Originally Posted by 67427vette View Post
      Thank you
      - - - Updated - - -
      Quote Originally Posted by LS6 Tommy View Post
      Tommy
      5th gear is 1:1 its by funny on the street and its not a daily driver
      Gear ratio is 2.23
      Maylon
