      Jun 2010
      Deployed
      ARP Bolt Torque Specs
      When you all swap out stock hardware for ARP hardware on LS aluminum blocks, do you use the ARP general torque specs or GM stock specs? I know the torque is to acheive proper stretch of the fastener, but seems ARP specs are very high.
      1970 Camaro/DSE build
      Which hardware are you talking about, exactly?
      Jun 2010
      Deployed
      Bolts like the LS water pump. The instructions say to see their generic specs.,
      I would use the GM specs and make sure to use antisleeze....as I recall the water pump bolts are 8mm? Don't need a lot of torque.
      Oct 2009
      Waterpump bolt specs are 11lbft first pass then 22lbft final pass
      1969 frost green camaro
      LS3
      Speedtech pro touring front subframe
      ridetech rear 4-link
      moser 12 bolt eaton tru trac 3.73
