Results 61 to 80 of 93
Thread: 1966 Nova SS Build
02-04-2020 #61
Trunk Welded Up
The final fit up of the trunk panels and the panels welded in place:
02-04-2020 #62
Cabin floor panel instalation and fabrication just foreward of DSE inner wheel houses
The cabin floor panels installed and welded up, all the metal up to this point is 16 gauge:
02-04-2020 #63
Port side header
The process of fitting headers:
02-04-2020 #64
Starboard Side Header
Building the header.
This side had challenges, route past starter, limited clearance,
02-04-2020 #65
More Starboard header Pics
More cutting and pasting!
02-04-2020 #66
Completed Mockup headers
here are the headers tacked up and pretty darn close! We will likely add some tube length to move the collectors a few inches back. The plan is to enquire about a nice set of fancy shiney Headers from a custom header place. Here are patterns. We wilol weld these up for another project.
02-11-2020 #67
The Firewall
Layout and Fitting of the Firewall:
02-16-2020 #68
Fire Wall Installed
Firewall Installed:
02-18-2020 #69
Some More Firewall Views
Pre firewall installation patch repairs:
First pici s of the last layer of bad metal.
Second pic is of the last layer of metal with rusted area cut out.
3rd pic is with the patch welded in and ground down.
4th pic is the last patch panel cut and bent to size, holes punched and ready to weld in place with weld through primer on.
5th pic is of last patch welded in place and ground. Now its ready for the firewall panel to be installed.
02-18-2020 #70
Installed Fire Wall Views
Fire Wall Prep And the Sectioned Area:
Section A was cut out of the firewall. Section B was moved over to where section A was because it had an indentation to it that matched the rest of the firewall. This section was moved over to make panel C come all the way over to the inner fender panel. This makes the firewall more "symmetrical". It would look odd to me if this step wasn't performed. Study the pics with the inner fenders in place for a better understanding
02-18-2020 #71
Firewall to Engine Clearance
The Squeeze:
02-18-2020 #72
More Engine Fire Wall Views
More Views
02-18-2020 #73
Drivers Side Floor Pan
Fabbing up the floor board.
02-28-2020 #74
Cowl Repair
There were a few issues to address on the drivers side cowl.
02-28-2020 #75
Cabin Work: Floor Pans and Front Frame Rails
The old frame rails:
Look closely and see all the spotwelds that were not holding
02-28-2020 #76
Repairing The Frame Rails
Repairing the frame rails.
Left side is in. Right side is cut out. New frame piece for right side can be seen in center of first pic sitting on the square tube. Bottom pic is the left rail welded in place
Right side rail fitted and clamped in place ready to be welded.
Next pic is welded in place
