Results 1 to 15 of 15
12-13-2018 #1
Shortening Ford Racing fuel injection harness
I have a Ford Racing control pack on my 68 F100. I have the ECM mounted into the firewall and the relay center in the interior. The wiring harness is looped across the right side of the engine.
The new supercharger intake sits 1/2 higher from the engine block so this gives me about 1.5 inches of clearance to run the wiring harness under the intake and really clean the engine compartment up.
There's about 30 to 40 wires that need to be shortened.
I have a few ideas on shorting the harness.
I dont know what type of pin terminals I need or where to buy them?
My other 2 ideas are cut and solder the wires together.
The quickest way looks to be the butt connectors that already have low temperature solder made into the connectors.
Can the wiring gurus please give me some ideas.
Thanks!!!
12-14-2018 #244 views and zero replies? Anyone?
Here's my truck so far. Valve covers will be painted white, supercharger will be blue with white start and the new intake will be red.
12-14-2018 #3I'll bite-
I am not familiar with that harness....
With that being said- I would NOT recommend just shortening it especially if it has any shielded wires (cam and crank sensors)- you are opening a can of worms there.
Being a factory harness- I would look for the pins and crimper - try these guys- I know they have the pins for Chevy LS stuff.
https://www.mouser.com/
You have done everything else correct (looking at the picture) and can't under stand why you would want to go with the "quick" fix on something as important- but unnoticed as the wiring.
Also look at this- for covering the wires and protecting from heat- for under $50- it's well worth the effort.
https://www.wirecare.com/category/br...me-temperature
I ran my crank and cam sensor wires "through" the engine- and just used some left over AN -12 hose to protect them.
12-15-2018 #4Thank you for replying. I did know certain wires cant be shortened because of changing values. I've thought of something else. Where the wires were looped across the engine, I can unpin the wires and loop them under the intake. I'm very precaution of wires chaffing. I will look into wirecare.com material.
They make all sorts of cool LS parts but the Ford's dont get near the attention until you see it run. Lol
Thanks again!
12-15-2018 #5
