12-10-2018 #1Registered User
- Nov 2011
- 126
Hydraulic clutch in 1970 chevelle
Hello all,
I have an American Powertrain hydraulic clutch kit for my 1970 chevelle that I'm having a very tough time installing. Everything has been good until I needed to install the master cylinder for the clutch and the associated linkage. I've tried installing it per their instructions with their "patented firewall mount" but I cannot get the correct location which will give me good pedal feel and no rubbing of the linkage on the firewall. I've drilled a couple holes in the clutch pedal trying to achieve the desired outcome but it's just not working. The firewall mount has not impressed me at all- if the mount is adjusted all the way down at its maximum limit the linkage rubs all over the bracket (why make a bracket with that much adjust-ability where you can't even use it all?). So I'm doing a lot of research and I've found other kits like the Mcleod kit (https://www.summitracing.com/parts/mcl-1434004) that uses a bracket that bolts behind the BRAKE master cylinder and provides the correct angle etc etc. They don't sell this bracket by itself and from what I've determined I probably couldn't use the bracket anyways with my stock style power brake booster being in the way. I looked into wilwood pedals but that creates whole other can of worms. So, has anyone successfully installed this kit on a chevelle with stock power brake booster and pedals? I'm pretty sure I'm just going to have to make my own bracket similar to the Mcleod kit.
Doug
1970 chevelle, carb'd, turbo'd 383ci with a tremec tko.
