12-05-2018 #1
Eliminating the soft lines on the typical rear disc brake conversions??
I put one of those cadillac caliper disc brake conversions on the rear of my 71 camaro. These kits supply you with two short rubber lines with banjo fittings on one end for the calipers and a 3/8-24" female end to thread your stock hard line into.
I don't really like the rubber lines and since there are no moving parts on this section of the brake system I thought about bending my own 3/16" line and going from the junction block on the axle directly to the calipers.
Has anyone done this? I don't see any reason why it wouldn't work, just wanted to check
The only issue I can see is addressing the banjo fittings at the caliper....but a quick search I can get a 10mm banjo fitting with an -AN on it...then I can use an -An compression fitting on the 3/16" tube to mate to that.My build thread
http://www.nastyz28.com/forum/showthread.php?t=241037
Paint Jail Experience
https://sites.google.com/site/paintjail/home
