    Results 1 to 15 of 15
      Jul 2001
      Detroit, Michigan
      '68 Camaro Interior Air Vents as ornamental only.......
      Let me explain....
      I have no heater or air conditioning in my car (nor will I ever) but I notice that without all the ductwork behind them there appears to be nowhere to bolt on the air vents on the dash.
      Is anyone else using their air ducts as ornamental only and how did you fasten them to the dash?
      1968 Pro-Touring Camaro LS1
      Project: Next Year
      - Start date; June '01
      TuoCo, CA
      Are you talking about the Astro Vent?
      Steve
      Check it Out Here
      Jul 2001
      Detroit, Michigan
      Quote Originally Posted by eville View Post
      Yes
      Project: Next Year
      TuoCo, CA
      The ball and bezel connect to the valve assembly and a screw holds it all tight. You might not want heat or air but the astrovent is nice.
      Steve
      Check it Out Here
      Jul 2001
      Detroit, Michigan
      I don't think I have the Valve Assemblies any longer. I'm going to have to do a little backyard engineering I'm afraid.
      Project: Next Year
      Jacksonville, FL
      Yeah the factory vents are held to the dash with one screw. Do you have all of the other pieces? With all of the ducting, there is no “tension”. All of the pieces from the firewall just plug into each other. If you are missing parts, I am sure there are guys on the board (that have converted to Vintage Air) that would have any parts you might need.
      Chris
      1968 Chevy Camaro SS
      LS3/T56 DSE suspension
      TuoCo, CA
      Steve
      Check it Out Here
      Jul 2001
      Detroit, Michigan
      That guy is 5 minutes from where I live. But not a very nice guy at all. We have a National Parts Depot in Canton (about 45 minutes away) and I actually go there instead for my parts just to avoid him.
      Project: Next Year
      Jacksonville, FL
      If you need the part that attaches to the cowl, I have an extra set.
      Chris
      Central Florida
      Quote Originally Posted by trapin View Post
      Not the first time I heard this.
      BB
      TuoCo, CA
      It was the first google search. Wasn’t an endorsement
      Steve
      Check it Out Here
      Jul 2001
      Detroit, Michigan
      Quote Originally Posted by 130fe View Post
      Chris can you take a pic of what they look like? I might have them lying around in a box somewhere. Thanks.
      Project: Next Year
      Jacksonville, FL
      Here are a couple of pics of all of the pieces individually and together. The harder ones to find (if you are missing them) is the piece that is attached to the firewall. I have an extra set of those but just left town for work. Won’t be home the holidays but if you need it let me know.
      Chris
      Jul 2001
      Detroit, Michigan
      I don't see any pics.....????
      Project: Next Year
      Jacksonville, FL
Size:  330.9 KBName:  6582C565-13B3-408F-AA59-7B8A6D4AF6F8.jpeg
Size:  161.2 KBWas trying to use the PT app but couldn’t post pics. Let’s try this again.
      Chris
