    Results 1 to 8 of 8
      Jul 2016
      McLeod T/O bearing 69 camaro TKO 600
      Hey guys, anyone running a McLeod hydraulic T/O bearing set-up ?? What kind of "play" in the pedal do you have ?? My pedal pretty much is close to the floor and it seems like I have a 1/2 inch of "play". Almost feels like I cant press the pedal anymore without hitting the floor and I'm still in gear. All of the air appears to be bleed out. Also the pedal is adjusted all the way up. Hmmm.
      What size MC? What style of clutch?
      Jul 2016
      Mcleod 1969 camaro hydraulic conversion kit. Not sure of the size of the master. McLeod clutch also.
      Have you called their tech support?
      Jul 2016
      Tomorrow I'll give them a call. Not to confident with Mcleod tech support to be honest. During my install of T/O bearing and clutch selection I received 5 different answers when I asked the same question to 5 diff techs.
      Quote Originally Posted by DT69Cam View Post
      I hate it when that happens. Did you make sure you have a proper airgap set?
      Jul 2016
      Yes. I'm hoping I still have some air in the system even though it appeared I removed all the air when bleeding. I don't feel like removing trans again LOL. Thx
      Oct 2008
      Toronto, Canada
      I don't have 1st hand experience with the Mcleod product but they have 2 TOB's .....#1300 for measurements A less than 3" & the #1400 one for measurements A more than 3". Double check any notes you might have. https://www.mcleodracing.com/index.p...-bearings.html
      Another thing is the air gap, approx. .150" on a single disc or .200" on a dual disc but depends upon maufacturers.
      I've decided to use Ram #78131 for my 5spd conversion but I'm not there yet.
