    Page 2 of 2 FirstFirst 1 2
    Results 21 to 33 of 33
    1. #21
      Jan 2018
      Saint Louis, Missouri
      Quote Originally Posted by ddavisart View Post
      What size fuse are you guys running on the positive cable near the battery?
      There will not be one size fuse that will work in all situations. Look at a late model fuse block and you will probably see anywhere from a 5A fuse to a 150A or more. Each fuse is designed to offer protection in the particular circuit design and each one has it's own characteristics. If you do some searches you will find fuses that may have the same amperage rating but they will have different operating characteristics.
      When designing or adding something like a fuse, circuit breaker, fusible link, and so on, one needs to do the work to figure out the best application. Get it wrong and things will not be protected as they should be.
      I think we all would like an "easy answer" to some things but the more specific one is as to what they want to do will give a better design and results. For example, a stock 60's style GM starter may draw let's say 200A on a 8.5 compression motor and a smog cam installed with minimal cranking compression but if this same starter is used on a higher compression motor with a higher cranking compression it will draw more power. If one were then to possibly swap out and use use a gear reduction starter with a lower horsepower motor it might draw more power than a higher horsepower gear reduction starter assembly and then either or both of these could draw more or less power than the standard 60's GM style starter.
      Jim
    2. #22
      Jun 2015
      Carlsbad
      Hey Jim, you are right and that completely makes sense. The better question probably would of been how are you determining the battery fuse size?
      I'm not new to cars builds, but definitely have a ways to go when it comes to rewiring/electronics. I'm trying to get there and pick up stuff where I can. I'm in the middle for wiring up my current build based on a Classic Update kit I was pointed to after talking with American Autowire and giving them my car specs. I trust that they steered me the right direction. The kit is pretty complete, well documented and easy to follow but doesn't account for things like master kill switches or remote solenoids keeping the live wire count down. So there is still a good amount to still figure out considering I have quite a bit of modern upgrades (Ls3, ecu, amp gauges...etc). I've been digging through alot of posts, but there is also alot of wrong information out there to make it more confusing. If you got any recommendations on how to dive deeper into this stuff let me know. I have no problem following setups, but I would be lying if I said I fully understood it all.
      Cheers
      Dustin
    3. #23
      Feb 2019
      Kankakee IL
      Some have mentioned using welding cable for trunk mounts. While it will handle the power the rubber shielding on it is not chemical resistant and can disintegrate over time.
      In all my trunk mounts ,and other wiring projects,I've spent a little extra and used large gauge marine cable. It is multi strand for flexibility and has the benefit of the strands being tinned as it's made for corrosion protection.
      And by all means stay away from CCA (CCAW) wire which is a cheaper type of wire made up of aluminum wire clad in a copper coating. Foot per foot it cannot handle the current of the same size copper wire. If the price seems to good check to see if it's CCA.
      Tracey
    4. #24
      Jun 2010
      Deployed
      I found this awesome marine cable on EBay, it’s super flexible and has two layers of insulation. I’m going to swap all my quick car cable out one of these days
      1970 Camaro/DSE build
    5. #25
      Feb 2006
      Phoenix, AZ
      300A breaker with valet. Makes an easy disconnect when needed.
      https://www.ebay.com/itm/0-4-Gauge-3....c100005.m1851
      1970RS Camaro
      Lateral Dynamics, Wilwood, BOZE, Strange Engineering, Alston, Ride Tech, Gen II, FAST.
      Dave Cozzi
    6. #26
      Jonesboro, Arkansas
      I don't know about starter run-on, but I had to install a diode in the alternator voltage sensor wire in order to stop engine run-on.
      So did I, I was really wondering what was going on the first time I started my car, turned it off at the switch and it kept running....
      Carl Wilson
    7. #27
      Jun 2010
      Deployed
      I’m to the point I need to do something...breaker or fuse...it’s such a hard decision.
    8. #28
      Feb 2013
      Would you rather carry a spare fuse or try to find a replacement breaker when it fails?
    9. #29
      Jan 2018
      On installs I have done I have used fuse holders with threaded studs that terminated wires connect to and then use ANL fuses. When I'm doing this I normally zip tie a second fuse to the wire so it's handy if needed and then have one cable going to one of the studs long enough to where one could bypass the fuse holder's two studs and have all of the wires connected to one stud. You would be bypassing the fuse BUT could get you by in a pinch.You would also need to keep in the car a wrench for the fuse holder studs.
      Keep in mind there are fuse holders and circuit breakers that clamp onto the stripped end of a wire but this type of connection would be harder to jumper across should one need to do that out in the middle of nowhere.
      Jim
    10. #30
      May 2018
      way east on a rock
      Being around the marine industry my whole life,I have wired cars kinda like boats. Somewhat archaic and not as pretty by PS standards, but the products are bulletproof and proven. This time around I'm reading alot and trying to come into the 21rst century,,,
    11. #31
      Apr 2010
      Jersey Shore
      Quote Originally Posted by JustJohn View Post
      Most automotive breakers work the same way that the one in your house does... If a quality breaker actually fails, youve got bigger problems.
      So, would you rather flip a breaker switch? Or carry a bunch of Maxi or ANL fuses around (and not every parts store carries these in 100+ Amp)
      -Chris
      '69 Corvette
      '55 Chevy Hardtop
      AutoWorks Middletown, NJ
    12. #32
      Dec 2010
      Fredericksburg, VA.
      It's not a hard decision at all, use a circuit breaker! Why would you want to have to carry around a spare fuse? Keep in mind, this fuse would not be like a standard automotive fuse you can pickup at any auto parts store or box store auto dept. Both a fuse and circuit breaker will do the exact same job, the difference is that circuit breaker can be reset which is handy if you are stranded. I just see no advantage to using a fuse.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Given sufficient initial acceleration, even pigs can fly!
    13. #33
      Apr 2016
      Following for my project!
