    Results 1 to 20 of 20
      Oct 2006
      McKinney, TX
      Firewall passthrough?
      Just curious how you ran your harness, and what did you use if you ran it into the passenger compartment.
      Pics of your wire hiding/routing would be awesome!
      Confucius says, "Choose a job you love, and you will never have to work a day in your life"
      My build Beast
      Nov 2010
      What kind of car and which harness are you running?
      I've used the daystar grommet for the firewall pass thru. More cost effective is making a trip to the local salvage yard and collect a bunch of various grommets from wrecked cars. Firewall grommets and door grommets of all shapes and sizes. I bought a bunch for $10.
      Oct 2014
      DFW, Texas
      There is a split grommet that gets riveted into place that summit sells for about $30. I’ll have to dig up the name, but it worked pretty well. It allows for a big enough hole to route connectors and closes back up to a reasonable harness diameter.
      1976 Dodge D100 - Warlock
      2016 Subaru WRX - E30 Tune
      Atlanta, GA
      I used one from a junkyard (OK- my parts car in the garage!)-
      Here's a couple of ways-
      https://www.diyautotune.com/product/...et-1-00-split/
      Here's another-
      https://www.diyautotune.com/product/...connector-kit/
      Oct 2006
      McKinney, TX
      Quote Originally Posted by firebirdzig View Post
      I have a 67 camaro. The main body harness is going through the factory location by the steering column, but im at a loss for what to do about the engine harness for the fitech system. Im up for any ideas.
      My build Beast
      Oct 2014
      DFW, Texas
      Quote Originally Posted by Richard454 View Post
      I have the seals-it, works pretty well. It's about the only game in town to pass through giant connectors.
      Oct 2006
      McKinney, TX
      Anybody run the ecm in the engine compartment? How did you hide the wiring? Im just trying to get ideas/options. A passthrough would clean it up quite a bit, but im curious about running it in the engine bay as well.
      Thanks to the idwas so far. Ive considered the seals it, but havent seen the connectors.
      My build Beast
      May 2013
      Colton Ca.
      I'm going to use the ones in the link below. They're about the 8th item down the page. They're the most affordable bulkhead and make engine removal easier. You use regular wire terminal crimpers so that makes them more affordable.
      https://paradiseracing.com/page/2/?p...duct&s=Harness
      Ahmad B.
      Aug 2016
      Tampa FL
      What harness for FITECH ? I was planning that as a future upgrade, But I am all out of under dash space !
      But Also to your point--> I added spade connectors to empty slots of the bulkhead connector to add some of my engine area wiring.
      Oct 2006
      McKinney, TX
      Quote Originally Posted by Build-It-Break-It View Post
      That looks really good also. Thanks for the idea
      My build Beast
      May 2019
      Pensacola,Fl.
      Feb 2019
      Kankakee IL
      An inexpensive item that makes a nice firewall grommet is a gladhand gasket used for semi truck. They're cheap and can pass a 2/0 cable through the hole.
      Tracey
      Here is another low cost option I just came across.
      https://ceautoelectricsupply.com/pro...wall-grommets/
      Oct 2019
      Are these solutions reliable enough?
      Southern California / Maryland
      I use Mil spec MS3470 connectors - Large bulkhead connectors I use the 32 pin style - Smaller ones I use for things like wiper motors and what not.
      downside is the cost
      1966 Chevrolet Chevelle 300 Deluxe 350 / 350 auto
      1968 Dodge Charger SRT8 6.1L Hemi / 6-speed
      1964 Dodge Polara 8-71 Blown 440 / 4-speed
      1998 Toyota 4Runner SR5 3.4L / 5-speed
      2013 Dodge Challenger R/T 5.7L Hemi / 6-speed
      TuoCo, CA
      And the cost of the tools to crimp
      Steve
      Check it Out Here
      Feb 2019
      Kankakee IL
      A tool that will always come in handy though.
      Tracey
      Quote Originally Posted by eville View Post
      Yeah - that for sure is a kick in the junk. I actually got mine at a yard sale for $10 since no one knew what it was used for.
      TuoCo, CA
      That’s pretty good. I paid about $200 on eBay and thought that was “decent”
      Steve
      Check it Out Here
