      Jul 2014
      Las Vegas , Nevada
      Stand alone oil system
      Has any one here done a oil system for just the turbos ?
      800 Amp Time Attack Thunderbird
      Nov 2016
      Sulphur, La
      If oiling is an issue for your build what about the self contained turbos? Does comp still make those?
      Apr 2008
      La Verne CA
      Quote Originally Posted by CSG View Post
      Yes Comp does make the self-contained turbos. They do require coolant lines to be plumbed to them.
      Quote Originally Posted by Bird of Prey View Post
      The question of why begs to be asked....
      Instagram @projectgattago
      Dr. EFI
      Jul 2014
      Las Vegas , Nevada
      I thought it would run cooler .
      Dec 2010
      Fredericksburg, VA.
      The oil is not the heat source in a turbo.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Given sufficient initial acceleration, even pigs can fly!
      What would run cooler? The engine? The turbo? The oil?
      Dr. EFI
      Mar 2011
      Ca
      no real point to stand alone oil for turbo as said above oil isn't the source of the heat, if you're worried about heating the oil up install a cooler.
