      Sep 2017
      TKO600 Noise in 66 Biscayne
      I just had a TKO600 kit installed. New bellhousing, flywheel, clutch, hydraulic clutch conversion all from american powertrain.
      When the car is sitting still it sounds perfect, when I start to push in on the clutch it makes a vibrating noise (its a hard noise to describe) car still runs perfect. Smooth shifting and clutch seems to work perect.
      Any ideas?
      Feb 2016
      Lawrenceville, IL
      Does it ONLY make the noise when your pushing the clutch pedal in? Or is the noise present at other times?
      visit us on the web at www.bowlertransmissions.com
      Sep 2017
      Makes the noise while driving too. Again, no vibrations are noticeable. Car still drives 100% perfect minus the noise.
      When the car is cold, the noise is not there. It takes a few minutes for the noise to start.
      There is only 150 miles on the entire kit BTW. Could this be something breaking in?
      TuoCo, CA
      Nope. Bad pilot or bad release bearing.
      Steve
      Check it Out Here
      Feb 2016
      Lawrenceville, IL
      I'm leaning more towards release bearing. My initial thought was bellhousing misalignment, but if you're saying that the clutch engages and releases smooth and it shifts ok I would then have to lean towards the release bearing.
      Sep 2017
      I found the issue. The flywheel was just veryvery slightly rubbing the inspection cover of the bellhousing! Add a stainless washer and a spacer and we are now good to go!
      May 2018
      way east on a rock
      gotta love those easy fixes.
