    Results 1 to 15 of 15
      Dec 2008
      Detroit
      C6 Z06 Caliper bleeder repair
      I was disassembling my calipers for powder coating and and found that the threads on one of my bleeder holes is stripped. Can anyone recommend a reliable repair method or someone that fixes this? Would like to get is done before PC in case its intrusive.
      ThanksName:  Photo Sep 09, 9 59 07 PM.jpg
      Big dreams, small pockets....
      Chris--
      '72 Cutlass S LSA/T56 Magnum
      Bowler Performance, Rushforth Wheels, ATS, Holley EFI, KORE3, Ridetech
      Project Motor City Madness
      Central Florida
      Chris,
      I did a quick Google search and found a couple of viable options in repair kits, you should be able to get them at a local parts store. Not sure exactly on your caliper size bleeder but I seen they offer some for motorcycles too which are fairly small if you needed a small one.
      Good luck
      BB
      Dec 2008
      Detroit
      Quote Originally Posted by Bad Bowtie View Post
      Chris,
      Good luck
      BB
      Thanks, I found a couple of options after I posted this last night. I'm going to hit the auto parts store today. I want to have this resolve so I can drop the calipers this week.
      Chris--
      Jun 2010
      Deployed
      Personally, I would hit up autozone for new caliper instead.
      1970 Camaro/DSE build
      Dec 2008
      Detroit
      I’m going to helicoil it. It ordered a kit last night.
      Chris--
      May 2010
      kitchener,Ontario,Canada
      Yes a properly installed heli coil or drill and tap to a larger bleeder size should do the job for you, worse case you will need to buy a new caliper .
      Ryan Austin
      On twitter @raustinss
      On Instagram austinss70
      Jun 2010
      Deployed
      Personally I don’t see fixing it is as cost effective nor for someone like me....it will always bug me the caliper isn’t perfect and has a different size bleeder in it. Especially if I was investing money into them such as PC.
      They are not expensive at the Zone.
      Dec 2008
      Detroit
      Personally I don’t see fixing it is as cost effective nor for someone like me....it will always bug me the caliper isn’t perfect and has a different size bleeder in it. Especially if I was investing money into them such as PC. They are not expensive at the Zone.
      The bleeder will be the same size with the Heli Coil and AZ doesn't carry the z06 calipers as listed. The calipers they sell are the J55 pkg, the z06 is j56. I had looked there before I thought of repairing.
      Chris--
      Feb 2011
      dallas, tx
      i would go to the auto parts store and see if there a next size up bleeder screw and tap it
      Feb 2011
      dallas, tx
      7/16 is alittle bigger than 10mm right?
      https://www.summitracing.com/parts/agb-s11410
      May 2010
      Yes ... 10 mm is a sliver larger than 3/8 ... btw to convert take the measurement and multiply or divide by 25.4 .... .375x25.4 =9.525 mm
      Ryan Austin
      USA
      Make sure not to drill and tap too deep. Remember, the bottom of the cavity is tapered so the bleeder screw ( which is also tapered ) will seal. Don't drill it till its flat .
      Jeff Tate
      U.S.A.
      Dec 2008
      Detroit
      Quote Originally Posted by JEFFTATE View Post
      I plan on marking the drill bit and the tap so I know exactly how deep I'm going in during the process. I'll take my time in the best effort not to ruin the caliper.
      Chris--
      Jun 2006
      Katy,TX
      Worse case you can tap for NPT and use a Wilwood bleeder as it has both pieces.
      1965 GTO project car
      2004 Pulse Red GTO
      Dec 2008
      Detroit
      Quote Originally Posted by Skip Fix View Post
      I popped a heli coil in over the weekend, calipers are at the coater now.
      Chris--
