    Results 1 to 17 of 17
      Camaro & Chevelle Convertible front 3 point Seat belts
      The wait for Convertible seat belts is a thing of the past.
      Check out our Patented new 3 point front seat belts for 1967 - 1969 Camaro Convertibles.
      Also 66 - 67 Chevelle Convertible.
      Check our web page www.morrisclassic.com Any questions call us.
      Thx, Billy
      Install video is on our web page
      Thx
      Jul 2011
      Nashville/ Tampa
      Maybe I'm simply not seeing it, but anything for 71 convertibles?
      Chuck,
      We are working on the 68-72 Chevelle ones. All of our parts are year and car specific so they will
      fit your car.
      Call us if you want to be put on the will call list when they are available.
      864-987-0032
      Thx, Billy
      Jul 2011
      Nashville/ Tampa
      Cool, I'm thinking I need something sooner than later so will likely explore other options, but I'll check back just in case.
      Chuck,
      We are placing a laser cut order next week to have them cut , then bent.
      Probably about 2 weeks. We have a Patented design that has been tested to 5000#.
      I hope you wait because there isn't anyone else that makes a Safe set.
      Almost a bolt in fit. You will need to only drill 1 hole for install.
      Install should take about an hour.
      The way everyone else mounts them is dangerous IMHO.
      Members get 5% discount.
      Thx, Billy
      Jul 2011
      Nashville/ Tampa
      I can do two weeks I think. Thanks for the info.
      Chuck,
      We will do all we can to get the brackets ready for sale ASAP.
      If I had a convertible I would not mount the 3rd point in the window
      sill area or the reel on the side panel as these areas were not made
      to support the extreme load of a 3 point top mount. Mounting in these
      places will break your collar bone & crush your spine.
      We have had the brackets pull tested to over 3 times the load required by FMVSS standards.
      But just consider that you can't drive for someone else notbeing attentive while driving.
      Call if you want more info
      Thx, Billy
      Jul 2011
      Nashville/ Tampa
      Will yours work with non-stock seats? I was going to be installing some Sparcos or similar.
      The stock brackets you will need 3 " between the seat and door panel.
      We have other brackets that set the reel behind the seat 6.5" most use these
      with wider seats like the TMI ones.
      If you have any questions call us
      Thx
      Our Convertible 3 Point Seat belts are a bolt in addition for the Safety
      of everyone buckled up.
      Pull tested to 5000# even though FMVSS standards are 1500#
      Comfortable to wear and look great in the vehicle.
      1968 - 1972 Chevelle Convertible ones will be available next week!!
      Billy
      Jul 2011
      Nashville/ Tampa
      Any updates on these?
      Chuck,
      Yes the 68-72 Chevelle Convertible seat belts can be ordered.
      Just give us a call
      Thx, Billy
      Jan 2016
      Will the 66 convertible 3pt belt work on a 66 hardtop? I like that shoulder belt node is mounted lower so you can't see it in the window.
      Chris Johnson
      '66 Chevelle Malibu
      Chris,
      Hard top & Convertible brackets will not interchange.
      All of our seat belts are year and car specific
      Billy
      Jan 2016
      Quote Originally Posted by morrisclassic View Post
      Chris,
      Billy
      And your 66 Chevelle hard top bracket mounts to the roof/pillar area near the rear passengers head?
      Chris Johnson
      '66 Chevelle Malibu
      Send an email to [email protected] for a picture.
      Thx
