    Results 1 to 16 of 16
      May 2011
      Gates Power Grip hose clamp removal
      At the time I thought it was very "cool" to use these new gates shrink hose clamps on the heater hoses. Now that I have to remove a few to change out the water pump, I just don't feel like paying $40.00 plus $$$ for their removal tool unless I have too. Is there an alternative way? Sharp new razor blade?? Thank you.
      64 F-85 post car Resto-Mod project-my RV when I retire
      Beach Park IL
      The tool works really slick.
      You can cut them with a box cutter......just be careful if you are trying to save the hose that you don't cut through.
      Donny
      May 2011
      HMM that's what I'm afraid of, especially in hard to reach areas.
      Beach Park IL
      If you can get in there with a small pair of snips and knick an edge, they will tear apart. They are more like plastic at this point.
      Donny
      May 2011
      That may work, since you just tip it , should come apart with w little love!. I have a pair of small nips to get it started...
      Oct 2014
      DFW, Texas
      I'd probably use an exacto knife going down it with the square side touching the hose.
      1976 Dodge D100 - Warlock
      2016 Subaru WRX - E30 Tune
      Feb 2011
      dallas, tx
      Heat, thin razor blade slit with a flat head screw driver in between the hose and clamp. Don’t be afraid you will get the hang of it
      Jacksonville, FL
      Yeah, I bought the correct tool and it works pretty well. I think I got mine through Jegs.
      Chris
      1968 Chevy Camaro SS
      LS3/T56 DSE suspension
      Newbury Park, CA
      I've had the tool for 15 years and only sometimes use it. Unless it is really straight it can still damage the hose cover.
      On the other hand, a soldering iron works awesome to cut the clamp. Just don't dwell on one spot too long and mind the rubber hose. Just lightly "saw" away at the clamp.
      Last time I went shopping McMaster Carr was the least expensive vendor for the clamps. NAPA has them too branded with their name but are Gates products.
      May 2011
      I like the idea of the soldering iron as I have one. I will give that a try. Thanks.
      Screwdriver and boxcutter with a new blade works great, like iceman said.
      John Parsons
      El Paso, Texas
      Rockauto is now carrying them as well and are priced way better than NAPA.
      I have always used a soldering iron to remove them.
      May 2010
      Livermore CA
      Soldering iron but I will not use them anymore. To much of a risk if a roadside or track repair is needed.
      May 2011
      I do think once these are off I'm going back to the standard hose clamps...
      Mine have been installed for ten years. Lmao.
      If you're worried about road side repairs, toss regular hose clamps in your tool bag.
