    Page 2 of 4 FirstFirst 1 2 3 4 LastLast
    Results 21 to 40 of 77
    1. #21
      Feb 2015
      Ride Height
      About ready to start looking for some new shoes. I don’t think the old centerlines will pass for pro-touring.
      Eze_1978 1968 Chevy Nova
      My build link:
      https://www.pro-touring.com/threads/...ova?highlight=
    2. #22
      Feb 2015
      Intstalling a Aeromotive stealth fuel tank with Stealth In-tank fuel pump. New carb. Regulator. Should be much quieter than the old external fuel pump. Name:  IMG_0045.JPG
      My build link:
    3. #23
      Feb 2015
      My build link:
    4. #24
      Mar 2019
      AG central coast CA
      Looks Awesome , I’m jealous of the rear suspension.
    5. #25
      Jul 2008
      ohio
      great work man.. cant wait to see more
    6. #26
      Feb 2015
      Quote Originally Posted by Bobbywracing View Post
      Thanks. Looks like you have a nice build yourself. Good thing is you can aways upgrade. Will be completely drivable when I get it back in a few weeks so it will be interesting to see how it drives.
      My build link:
    7. #27
      Feb 2015
      Quote Originally Posted by craigs73 View Post
      Thanks appreciate it. Should get a lot more done here in the next 6 months or so.
      My build link:
    8. #28
      Feb 2015
      Pulled the trigger and put down a deposit on some new wheels. Going with an 18x9 in the front and 19x11 in the rear. Tires looking to put a 265 35 r18 in the front and 305 30 r19 out back. Need to measure and get the backspacing straight to make sure it will all work.
      Think about going with a Gunmetal Center with Satin black Barrels.
      My build link:
    9. #29
      Jul 2008
      ohio
      should be able to get 315s but not sure with 19s i cant wait to see it done.. deposit? how does that work? i need new wheels at some point but prob not until the body work is done etc.. ones i have will work for now
    10. #30
      Feb 2015
      Limited selection in 315 for a 19in wheel. Either a 305 or 325 is what is most available. I called Matt Classic Bowties because they were having a sale through the 4th. and inquired about what sale they were offering with Forgeline. Kim said if I knew what size and and type of wheel I wanted and could put down half and they could have the order sent to forgeline. I was able to get all the brake information since I already had the specs from Wilwood. They also have a fitment tool they lone out, so I am able to get the backspacing to them later once that tool becomes available and pick up some tires in the next week or two. Great customer service Kim MCB even return my call after hours.
      My build link:
    11. #31
      Feb 2015
      Aeromotive stealth tank installed.
      Lines plumbed
      My build link:
    12. #32
      Feb 2015
      Got the car home. Measuring final wheel fitment.
      Rears will be a 19x11 with a 6.25in backspace.
      Fronts decided to reduce the tire size to a 245 35 R18 to be able to tuck the tire a bit for a little lower stance. Came out to a 5.25 backspacing.
      Thanks to Matt’s Classic Bowties for the loaner wheel fitment tool.
      My build link:
    13. #33
      Feb 2015
      Got the new Forgeline GX3 wheels in today. They are graphite with Satin Black. Hopefully, all my measurements were correct.
      My build link:
    14. #34
      Feb 2015
      Test fitted the wheels today. Looks like the rears will clear perfectly. Will need to adjust the axel a little bit. 1in clearance on passenger side 9/16 on drivers side. I’m really liking how these turned out. Now need to check the fronts before we mount the tires.
      My build link:
    15. #35
      Apr 2017
      Carlsbad, CA
      Those look great. On the back though, I would cycle the suspension with the springs out and see how close the the rear wheel get to the tubs/chassis.
      1963 Ford Falcon
      -331 Stroker Motor 450hp, 2700lbs
      2014 Ram 1500 Quad Cab Hemi
    16. #36
      Feb 2015
      Quote Originally Posted by NorthFalcon View Post
      I will definitely take that advice. I need to pull the shocks out anyways to do some painting.
      My build link:
    17. #37
      Feb 2015
      Everything fits great. I have a mild concern the front may hit the ridetech sway-bar arm. Lock to lock is fine no rubbing but if I crank the wheel hard it does just touch the wheel. I may just install a small bump stop so it doesn’t go too far just to be safe.
Size:  74.2 KB clears but if the then crank the wheel really hard it will touch.
      My build link:
    18. #38
      Aug 2015
      NJ
      If you have R&P steering all you have to do is add a clip to limit the range.
      '68 Chevy Camaro Pro-tour ~ project DMENTD
      '57 Chevy 3100 Pro-tour pickup ~ under construction
    19. #39
      Feb 2015
      Quote Originally Posted by pittpens24 View Post
      I’m running the stock style steering box.
      My build link:
    20. #40
      Feb 2015
      I was having a problem finding long tube headers that would work. After trying a couple pairs of different headers I found Sanderson Mid-Length CC16 Headers fit great and cleared everything with no problems. I just test fitted but was able to install them from the top of the engine bay. Clears the z-bar with plenty of room.
      My build link:
