Thread: FiTech "ECU no response"
08-05-2018 #1Registered User
- Sep 2004
- 11
I am having trouble getting my FiTech up and running. Ford small block, FiTech EFI, MSD 6. The handheld is working but when I go to initial setup I get "ECU no response". I have a separate wire direct to battery for the +12 volts, the white wire (key) has +12 volts in the on and start position, also tried a separate ground wire from battery to throttle body. The shop that built the motor dyno'd with the FiTech so I am thinking it must be something I have done or not done. Any suggestions?
10-17-2018 #2Registered User
- Oct 2018
- 1
Do you have the key turned on? You want to turn it on as if to start. Now the unit has power and can talk to the computer.
Bob
10-18-2018 #3
