      Sep 2011
      Manual Master cylinder for 70 Chevelle
      I have 70 Chevelle with OEM front disc brakes, late model s10 rear Disc brakes. Been running a with a booster and 1-1/8 master cylinder but never had enough brakes with the cam i was running, and now im switching to a larger cam. Im ditching the power booster and going full manual. I already have a universal 1" bore corvette style master cylinder but im unsure which port is front and which is rear, I pulled the pistons and the primary piston is the rear port so im guessing this should go to the front brakes.
      Im also on the fence whether or not that a 1" bore master cylinder is adequate or if i should go to 15/16 or 7/8.
      This is the master cylinder i already have.
      https://www.performanceonline.com/Di...ing-Valve-Kit/
      Loganville, GA
      On the Corvette master cylinder (1967-76), front port is for the front brakes, rear for rear. 1" bore should work with the brakes you have now.
      2018 Cruze LT Hatchback
      2003 Suburban 2500 8.1L
      1975 MGB Roadster
      2003 GSX750F Katana
      tx
      1" bore
      I cant imagine that 1" master wouldn't work as long as you have a 6:1 pedal ratio. I am using almost the same combo with 12" wildwood disk in front and factory drums on rear. I have crazy stopping power with normal non-power brake pedal effort. Its better to stick with the larger 1" bore if you can to get the increased fluid volume.
      66 Impala
      86 Corvette
      85 C20
      77 Cordoba
      If you want an inexpensive 15/16" option, check out a 79 Malibu with manual brakes.
      Instagram @projectgattago
      Dr. EFI
