Results 21 to 40 of 69
Thread: 1967 Camaro Restomod "Herja"
07-28-2018 #21Registered User
- May 2018
- 73
More progress on the portion of this build that any chevy enthusiest would consider to be Heresy..... The fabrication work to mount a 2016 Ford Mustang GT rear subframe. This is probably the most unique part of my build, as I've not seen it done before and I didn't want to spend $8,000+ for an independent rear suspension set up (I'm sure I could have done a solid axle 4 link set up for cheap that would have handled much the same), but for $450 bucks, this was a steal.
What you see on the pallet is what I got for that price. Spent another $500 bucks on the full tilt boogie racing bushing kits which you can see here the exact reason mustangs get a bad rep for being attracted to crowds
https://www.youtube.com/watch?v=Y7NWX6rZzdg
Clamped up the mini tubs (we had cut along the subframe line since we were going to be making mounts for the 8.8 IRS to mount up) in prep for getting all our measurements
More progress made on getting the rear subframe mounted up, rolled it under the car again and lowered it to get a better idea of where the mounts will be made and installed. I will say its a tedious process of mostly squaring up a 450 subframe, taking measurments, adjusting slightly 1/16 of an inch, remeasuring everything again, repeat....
In order to give ourselves better access to the area, I made the call to cut a good chunk of the trunk pan out that we'll weld back in later, well worth the time it will take to weld it back in and clean up.
Once we had the ballpark area and marked on the frame where we needed the mount points to be (within about 1/8th of an inch on the frame) we stripped everything off the rear subframe. Right now waiting on the mount hardware and full tilt boogie bushing kit to eliminate the nasty wheel hop these rear ends are notorious for. Still probably have another weeks worth of fabrication work once I get the bushings and mount bolts in for the rear, but hopefully by the end of august here I'll have a roller again and can start wheel shopping, which I'm very excited for (though my wallet isn't).
11-23-2018 #22Registered User- Join Date
- May 2018
- 73
Well, been a busy fall and now with college back in full swing, haven't had much time to work on the car. Right now its still sitting at needing the rear subframe mounts to get frabricated and the mini tubs to get finished. So for now im looking at options for steering, still undecided between the rack and pinion style or to go with something like a Lee box set up. Not sure how many follow this but looking for some insight as to which route would be better, budget for that is around 2k total (want a new column too) and will be going with an LS1 engine.
12-08-2018 #23Registered User- Join Date
- May 2018
- 73
Just purchased the 6.0L engine =) hopefully will get some work in on it between semesters, 2 more classes to go for my degree!
02-08-2019 #24Registered User- Join Date
- May 2018
- 73
Block has been at the machine shop now a month.... finally bored 65 over and rods and pistons on order. Pretty annoyed with the machine shop, is having a block for 1 month a bit ridiculous?
T.O.
1967 Camaro - "Herja"
02-08-2019 #25Registered User- Join Date
- Apr 2018
- Ozarks
- 46
