    Page 3 of 3 FirstFirst 1 2 3
    Results 41 to 55 of 55
    1. #41
      corona,ca.
      Just a small tip , when measuring the height of the car use a spot on the frame as the reference point for the measurement, too many people will use the wheel well opening which can vary a lot more vs a point on the frame. Cheers glad it all worked out in the end
      Thanks.
      Yeah I think the driver side spring rate is not the same as the passenger side,it has the 550 stamped on it put when I push on the driver fender side it's a lot more bouncy that the passenger side.
      The shock are adjusted at the same number.
      72 chevelle.
    2. #42
      corona,ca.
      Quote Originally Posted by Josh@ridetech View Post
      Looks good Phil!
      Thanks Josh!
      Question,I'm looking at getting some 650# spring,but they are 8.00 long spring,will these work with my 4.1+ 1.00 eyelet coilovers?
      Thank you josh!
      72 chevelle.
    3. #43
      Lawrenceburg, TN
      project is looking good, keep plugging at it, getting it right is hard work,
      I'm glad your posting all this so others see,
      just because it bolts together doesn't mean it works together
    4. #44
      corona,ca.
      Thanks!
      Yes,things like this Can be worked out thou,
      With the help of vendors,members and time to think things thru.
      72 chevelle.
    5. #45
      Feb 2013
      Quote Originally Posted by chevelletiger View Post
      Thanks Josh!
      Thank you josh!
      The 4.1" shocks really work the best with a 10" spring.
      If you were to use an 8" spring, it would either need a spacer or have to be really stiff for your car, so you don't run out of thread adjustment.
      Ridetech Suspsension
      Tech Specialist
      Phone: 812.481.4734
      Project Fox
      1979 Trans Am
    6. #46
      corona,ca.
      Josh,the spacer would go on top of the spring right?
      I got these for $40 for the pair,and there pretty new.
      I really just got them because I think one of the 10 inch 550lbs springs I got from an eBay seller seems to be softer then the other one even thou they are the same rate and length.
      I can always sell these after I install then to make sure that not the problem.
      Shocks were set at same length,so I don't know why one side looks higher,the passenger side compared to the driver side which looks lower.
      I hope thats all it is.
      Thanks Josh.
      Phil
      72 chevelle.
    7. #47
      Jan 2003
      Arizona
      For the purpose of helping other who might find this thread down the line, it might be helpful to recap: (Correct me if I'm wrong) The OP was concerned about getting his geometry right at ride height(lower control arms level) With that done, the concern moved to ordering coilovers with the perfect length for his combination of parts. The solution for anyone else in this situation is: Don't sweat it! ridetech can help you FINE TUNE your coilovers dimensions by changing mounting ends, spring cups and spring length/rate. We have a detailed article here: https://www.ridetech.com/info/custom...tion-of-parts/
      It's a common question, since no two hot rods are exactly the same. ..and it's a bigger issue with mixed parts. Just make sure you are buying coilovers, like RideTech, that CAN be tailored. Kudos to Phil (the OP) for wanting to get it right. A lot of people just settle for coilovers that bottom out.. top out.. crash...bang, etc. Don't settle.
      Steve
      ________________
      Steve Chryssos
    8. #48
      Feb 2013
      Thanks Josh.
      Phil
      Hey Phil,
      Something like our drop cap (replaces the upper spring retainer) would be the easiest thing. This will push the spring farther down on the threads so you'll get to keep the adjustment- https://www.ridetech.com/products/co...-retainer-cup/
      Tech Specialist
      Phone: 812.481.4734
      Project Fox
      1979 Trans Am
    9. #49
      corona,ca.
      Thanks josh,that works!
      72 chevelle.
    10. #50
      corona,ca.
      Updates on the coilovers.
      10" springs 550lbs.
      I think I need to add another spacer under the coil over.
      Now this question is for the ridetech fellas.
      The car,how it sits
      I got a rough measurement of 12.5 from the center of the t bar to the center of the upper chicane bracket.
      I'm I good?
      Coil spring nut is just snug tight onto spring both side
      72 chevelle.
    11. #51
      Jan 2003
      Arizona
      Is the rest of the car done? (meaning full weight?) It might be wise to leave it alone for now and finalize springs after you get the car on the ground. I realize that your wheel stands emulate a level surface, but there is nothing quite like seeing the car on the ground and tweaking from there. As for coil spring collar adjustment, close to zero-preload is the way to go. Plus a turn or two is fine. There is no law against cranking your springs up a bunch, but it's better to swap out springs in an effort to achieve low preload.
      Steve
      ________________
      Steve Chryssos
    12. #52
      corona,ca.
      Quote Originally Posted by Steve Chryssos View Post
      Steve
      Yes Steve car is all pretty much complete,I do still have iron head,that will be switched for aluminum ones.
      Phil
      72 chevelle.
    13. #53
      corona,ca.
      Found out why the passenger side was higher than the driver side.
      One of the 6 jack stands I have was under the header!
      Doh!
      Now the driver side is only about 1/2 lower,I know I need to adjust this.
      I still think the springs are too soft.
      Going to get some 750lbs.
      72 chevelle.
    14. #54
      Mar 2014
      Nebraska
      What springs did you end up going with? Do you recall what dimensions of the ridetech coil over?
      I have SPC control arms 550lb springs and I want to do either the speedtech chicane mount or the umi upper mount with ridetech coil overs.
      1968 Pontiac GTO pro touring LS1 T56 9"
    15. #55
      corona,ca.
      Sorry for the delayed response.
      Personally I like the chicane setup better,the umi one uses a 7 inch stroke shock,kinda overkill.
      I have specs on the shocks but you should measure for your car,there all a little different like women!
      - - - Updated - - -
      Still have the 550lbs haven't worked on the car in awhile.
      Doing body work on a friends 41 chevy coupe and my 70 c10 swb
      72 chevelle.
