    Results 1 to 19 of 19
      Oct 2011
      4L80E with Ford 9" gear ratio?
      68 Camaro
      LS3 motor (6500 rpm redline)
      4L80E trans
      Ford Fab rear end
      335/18 tire
      Should be at 500 na-600-650(turbo'd) at the rear wheels
      Contemplating between 3.25 and 3.50 gear ratios
      Street Car
      Thinking a lower gear ratio will work better with my hp goals?
      Fredericksburg, VA.
      What is the OD ratio of that transmission? Off the top of my head, I'm thinking more along the lines of 3.73. You need to find a good gear ratio calculator.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Apr 2012
      Woodstock, IL
      You will have better results with the lower number gear being a turbo car with that kind of power. But given that it’s a 4L80 which has a 2.48 first gear.. I’d go with the 3.50.
      If it was left n/a I’d go with a 3.89.
      SchwartzPerformance
      With that kind of power, I would do a 3.25 gear. If you have a bit of a stall, it will flash nicely of the line and make up any deficiencies. With the 3.25 gear and a 335/30-18 tire, you will run 2200rpm @ 75mph on the highway, which is about right, at least for me.
      May 2015
      I have 3.5's for my same set-up as yours, but mine will have a turbocharged inline 250 six cylinder.
      Oct 2011
      OD is .75
      Oct 2011
      What I am trying to avoid is the car just sitting there spinning at the line
      Pretty sure my old 2001 Trans Am had 3:42’s
      It had about 432 hp at the rear tires
      On brand new street tires, it would spin the tires almost off the rim, unless I launched at a very low speed and then worked my way into the throttle
      With that car, I had a T56 transmission
      To be fair, I only had the stock suspension on that car which was pretty poor
      This car has a billet g link setup
      I also have a 2500 stall converter
      First gear has a 2.48 ratio on the 4l80
      Final drive is .75
      Stock 4th gen f-bodies had 3.23 gears with the 4L60 and 3.42 gears with a T56. As I said, if it was my car, I would to 3.2x gears.
      Oct 2011
      Sounds good. I read an article that said it could depend on the stall converter I am using along with the power band of the motor and the camshaft as well
      I am using the East Coast supercharging small blower cam
      I am pretty sure the power band on the cam is mid to high range, so may want lower gears off the line
      Traction will be the main concern for me anyway
      What are the cam specs?
      Oct 2011
      Mid 230's, 588 lift on a 117 LSA
      Although on the Internet I hear 115 LSA
      ECS spent years of R&D and will not release the exact specs
      I am going to call them tomorrow to find out where the cam power range is
      Fredericksburg, VA.
      I have a G-link rear suspension and it is not great with forward bite. I can pretty much spin the tires at will. On a road course I have to be careful with throttle application on corner exit to avoid tire spin.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Oct 2011
      Sorry to hear that the G link is not good at controlling forward spin
      I was originally referred to Savitsky who told me that it was the best thing to control forward spin?
      May end up going with a 3.25 anyway
      Quote Originally Posted by Blevinator View Post
      That's a pretty healthy cam. I wouldn't be so worried about the power range as I would be about low RPM stability. Stock cams are very happy pulling a load on the highway at 1600-1800rpm. Bigger cams, not so much.
      My guess is that this cam should be fine around 2200rpm, which is what it would be turning at 75mph with 3.25 gears. Then again I tend to pick gear ratios based on good street and highway manners, and not so much for ultimate performance, although sometimes those two things end up being the same.
      Apr 2012
      Woodstock, IL
      4L80e is a .75 OD, Tremec calc says 2,354 RPM at 75mph. What were you going off of?
      3.00 gear would be 2,173 rpm.
      However with the 4L80e tall first and second gear (compare to a 4L60 or even a close ratio T56)
      it's going to "act" like you have a taller rear end gear in comparison.
      -Dale
      SchwartzPerformance
      Quote Originally Posted by Schwartz Performance View Post
      -Dale
      Dale,
      I was using a spreadsheet, but I just realized it has an error. After fixing it, I am getting 2317rpm @75mph and 2189@75 with a 3.00 gear.
      Jul 2012
      Traverse City, MI
      I dont know man. I had a 3.31 rear gear with my 4l80e and I was NOT happy with the acceleration of my 6L build and a 3200 stall. When I jumped up to 3.73 I could finally see the light.
      Project thread - https://www.pro-touring.com/threads/...ouring-Project
      IG - @tc_chevelle
      Quote Originally Posted by Barrrf View Post
      Did you have a turbo?
      Jul 2012
      Traverse City, MI
      Good call mod. I do NOT have a turbo.
      IG - @tc_chevelle
