Thread: vintage air gen iv need help
A little back ground, 69 camaro with gen 4 with the conversion for the orginal controls. I installed this and couldn't get it to work. Contacted vintage air and for a month diagnosed and replaced a few parts. What was determined is that the harness for the controls was wired from the factory wrong and took out the ecm and slide pots. V.a. sent me an ecm, harness for the controls and new pots. Programmed just fine but I don't have voltage to the binary switch. I checked voltage at the relay and nothing going to the switch. With the relay disconnected, I checked voltage at the other 3 terminals at the relay plug and get 12.97 at terminal 30, 12.97 at terminal 85 and 12.80 at terminal 86. This doesn't make sense to me, has anyone had this happen? I did try a different relay
