    Page 2 of 11 FirstFirst 1 2 3 4 5 6 7 ... LastLast
    Results 21 to 40 of 213
    1. #21
      Apr 2011
      Rosser Manitoba Canada
      Gives me a starting point, and if it allows me to get a setup that I like then it is perfect.
      Thank you for taking the time!
    2. #22
      Jun 2013
      Phoenix
      Thought I would spend some time on the brake lines. Progressive set up the under cab mount for a 7" vacuum booster, but I decided to go with a hydroboost so I cut out the mount and had a modified one water jetted out and moved the location a little to take advantage of the frame cut out.
    3. #23
      Oct 2017
      Oregon
      Very Nice!
    4. #24
      Jul 2018
      I know this is my first post, but looked like you need some help... so I finally made an account.
      A: 6.57deg
      B: 37.244" (945.99mm)
      C: 3.410" (86.63mm)
      D: 6.455" (163.96mm)
      E: 8.484" (215.50mm)
      Sending you a p.m.
    5. #25
      Jun 2013
      Phoenix
      Egoman: SpaceCadet has the accurate measurements. I was close, but no cigar...
    6. #26
      Cool build!
    7. #27
      Apr 2011
      Thank you for the time and the measurements. I have a small amount of stuff to complete before I start my build thread in earnest.
    8. #28
      Jun 2013
      Phoenix
      I see where one of my measurements was off(B). I measured from the inside of my frame rails. After studying the picture of the factory frame rail...big difference.
    9. #29
      Jun 2013
      Phoenix
      Getting the door gapping done and rounding the front corner of the door.Name:  IMG_4730.JPG
Size:  322.1 KBName:  IMG_4729.JPG
    10. #30
      Jan 2014
      Austin, TX
      very cool build
    11. #31
      Jun 2013
      Phoenix
      Been a while for updates.
      Chassis is ready to have the cab mounted and trial fit everything.
      I had a couple renderings done to get an idea of wheels, colors and grill.
      Here is what I have so far:Name:  proof1.jpg
Size:  311.3 KBName:  proof2.jpg
    12. #32
      Sep 2017
      I love the second rendering. Very cool build!
      1965 Buick Skylark Sport Coupe V8, Two Door Hardtop - Project
      2014 Mercedes Benz C300 Sport 4Matic - Daily
    13. #33
      Jun 2013
      Phoenix
      Finally kissed the cab to the chassis. Time for firewall work. I cut out the small hump and will recess it about 3".Name:  20181029_182744.jpg
Size:  164.0 KBName:  Resized95201810299518284695390.jpg
    14. #34
      Jun 2013
      Phoenix
      Well, I am working with Bob at Progressive. They made an honest mistake and my wheelbase is 110", not 114". The step in the picture is pushed up to the cab. The fender and step still need to be moved rearward another 1".
      I had a good conversation with Bob and worked on putting everything on the front to make sure it all mounted together. Fit great. The side rails to the rear are just short 4". Extending the frame will be the easy part. It's the torque tube that will be the pain. It will take about a month with the turn around times on shipping to be back on pace.
      - - - Updated - - -
      Bob and I worked things out (great guy to deal with!)
      I have the chassis on the frame machine. The front was just a little off so we pulled it level and now adding in some cross members. Next, we are getting the frame set up for a little lengthening in the rear.
    15. #35
      Oct 2015
      Are those 19" wheels on the rear?
    16. #36
      Jun 2013
      Phoenix
      Yes, 19" in the rear and 18" up front. I think the front need to be 19" too or more sidewall.
    17. #37
      Oct 2015
      I just have used/mismatched mock up tires on mine and the 18” fronts with more sidewall look way better than the lower profile 19” on the rear. I intend to change the rears to a higher profile on the rear. Btw, your build is looking very nice.
      www.pro-touring.com/showthread/117557-56-chevy-pu-C6/C5/LS
    18. #38
      Jun 2013
      Phoenix
      I agree. More sidewall the better on the 18". I'm going to try a larger tire on the rear and see what she looks like or go to an 18" rear too.
    19. #39
      Apr 2015
      SoCal
      Killer truck. Love the dash swap. Chassis is pretty drool worthy as well.
      CAM-T Autocross Fox Mustang
      LX mustang autocross on the "cheap"...
      1953 PickEmUp
      1953 Chev Pickemup
    20. #40
      Jun 2013
      Phoenix
      Here we go. Bob(Progressive) sent me some matching 2"x6" frame rail so I could extend the chassis. Today we built the inner sleeves to make sure that the extension will probably be the strongest part of the frame. Tomorrow we should have this completed, then torque tube comes out to get lengthened at Gamel Street Rods.Name:  IMG_5252.JPG
Size:  336.2 KBName:  IMG_5251.JPG
Size:  363.9 KBName:  IMG_5250.JPG
