Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 48
    Oct 2015
    Kansas
    Default 67 Chevelle Build
    Ive been meaning to start a build thread on my 67 Chevelle, so here goes. The first part of this thread will be catching up with about 9 months of progress. I casually looked for a nice 66 or 67 for several years, but hadn't had much luck. But in the summer of 2017, I came across this one on Craigslist. It's a really clean 67 Malibu that had buckets and a console automatic. The previous owner had it for 14 years. He had already replaced both full quarters, inner/outer wheelhouses, and repaired the package tray area. So, there wasnt any major rust repair that needs done. It came with a ton of new parts including all new interior pieces. It has a pretty mild 350 with a th350 trans and a high geared, open 10 bolt rearend.
    My goal is to make it a car that's both fun to drive, and comfortable. The plan as of right now is a big block with a tko600. It will still be a slow process since I will be do all the work myself in my shop as time allows. Heres some pictures of it when I brought it home and mocked up the trim and bumpers.
    Oct 2015
    Kansas
    Default
    I had Quick Performance build a 9" with 3.89 gears and an Eaton truetrac. Built to handle 650 hp. I doubt I will be throwing that much power at it, but I do plan on having too much power for the 8.2" 10 bolt.*
    I also ordered Wilwood front and rear brakes. 14" 4 piston rear, 14" 6 piston front from MCB Parts (great people to do business with btw)
    Pictures:
    Oct 2015
    Kansas
    Default
    A few more pictures of the rearend
    Oct 2015
    Kansas
    Default
    I went throught the instrument cluster and added aftermarket gauges from Shiftworks. Replaced or cleaned up every piece of the cluster I could. While this car will be a SS clone, I want to try to get as many of the small details correct. They aren't exact matches for the original guages, but they still look nice. Only a purist will know the difference. I also took the vent windows apart and replaced the rubber pieces. While I had them apart, I cleaned them up and repainted/polished them. They came out pretty nice I think.
    Oct 2015
    Kansas
    Default
    Suspension will consist of ridetech level 2 full coilover setup with Detroit Speed rear chassis braces. Pic is apparently sideways?
    Oct 2015
    Kansas
    Default
    Around Oct 2017 I started taking the car apart for paint. Before starting that process I put on a ABC Performance smooth firewall.
    Oct 2015
    Kansas
    Default
    Next I shot the interior parts with some satin black
    Oct 2015
    Kansas
    Default
    I used all Southern Polyurathanes products on this car from primers all the way to the color. It was my first time using their products, and I was very impressed with everything I used. A few pictures after stripping the car down and shooting the epoxy.
    Oct 2015
    Kansas
    Default
    Back panel painted black
    Oct 2015
    Kansas
    Default
    After many hours of blocking out high build, it was time for sealer and some color. Color is SPI red single stage
    Oct 2015
    Kansas
    Default
    A few more pictures straight out of the booth.
    Oct 2015
    Kansas
    Default
    Right after bringing it home from where I painted it.
    Oct 2015
    Kansas
    Default
    I then cut it down with 1500 then 2000 grit and polished using the 3m Perfect-it three step polishing compounds on white/black/blue foam pads. The florescent lighting in these pictures gives a pinkish look for some reason. I don't treat any of my old automobiles like show cars, and this one will be no different. So I was happy with how it turned out for a car that will be driven alot.
    Oct 2015
    Kansas
    Default
    I shot Lizard Skin sound and heat coating inside the trunk and on the inside of the quarters. I plan on spraying it on the inside of the floor pans later on also. I put Dynomat on the ceiling and inside the doors. Here's a shot of the trunk and a couple of pictures with the decklid and rear trim on.
    Oct 2015
    Kansas
    Default
    Next up was putting the doors on. This ended up being much harder than it should have been. The original hinges needed rebuilt, but I got lazy and just ordered new aftermarket ones. I should have known better, the doors would not even come close to fitting with the new hinges. After comparing them to the originals, I seen why. The casting on the lower hinges is so far off its ridiculous, and the holes were way off on the top hinges as well. So I rebuilt the originals like I should have done to begin with, and the doors bolted up without issue. I'm sure I don't need to tell anyone here how frustrating repro parts can be.
    Feb 2013
    Default
    Good looking car. Wish I had your paint skills.
    Oct 2015
    Kansas
    Default
    Quote Originally Posted by JustJohn View Post
    Thanks! I'm not sure how much skill i have, but I do have alot of patience. And to me, that's the key when it comes to painting.
    Some shots I took of the front suspension and brakes going on...
    Nov 2002
    Wichita Falls,TX
    Default
    Nice build, Jonathan.
    Aug 2009
    Phoenix area
    Default
    Looks great so far. What steering box are you using?
    Ric
    2002 s10, DD and AutoX.
    1966 Malibu owned since 1971. Drag car converting to track toy!
    Oct 2015
    Kansas
    Default
    Quote Originally Posted by USAZR1 View Post
    Thank you!
    Quote Originally Posted by rixtrix1 View Post
    It's a Jeep Grand Cherokee box. I put it on before I took the car apart, but I only got to put a few miles on it. I liked the way it felt MUCH better than the original box. We'll see how I like it once I get it on the road.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
