    Page 3 of 3 FirstFirst 1 2 3
    Results 41 to 47 of 47
    1. #41
      Central Florida
      KCR,
      Great job on the car. I know a lot of hours go into getting body work just where you want it, I am in the middle of that weld here, cut there, grind here lol. I did notice you were using port fuel injection and that's what I plan on I'm just curious to see what ecu you are using. I plan on a Holley Dominator so that I can control my 4L80E trans all in one unit. If you are using Holley how has it been with setting up the 540? Continued success on your build
      BB
    2. #42
      Mar 2015
      Bad Bowtie ,
      I'm using the Holley HP ECU. The set up was real easy. Just put in motor specs check all wiring and hit the key.
      I really need to update. Car is getting paint next weekend and goes to the upholstery shop end of the month
    3. #43
      Mar 2015
      Attachment 188197Name:  CE787C16-FF29-4F33-A2A7-7621C18E7959.jpg
Size:  414.3 KBName:  E52FA512-2FD7-4ECD-A6C8-2D27CCAF5EE4.jpg
Size:  349.9 KBHi All I did a really bad job at keeping up with this thread. The car is done and been driving and working out all the bugs of a new build. the biggest one was the TH400 didn't last long so a month or so ago we added a 4L60E built by Profomabuild what a beast and what a difference. With the TH400 the car only did 500 HP had to be something wrong with it from the start but now 600 + HP and overdrive. had some issues with the cooling but that turned out to be not getting enough voltage to the fans.
    4. #44
      Mar 2015
      For the interior I went with 2016 mustang seats hand built the center console and trunk area.
    5. #45
      Jonesboro, Arkansas
      what color is your car. I really like it.
      Carl Wilson
    6. #46
      Mar 2015
      The color is Rosetta Red from a 2019 Range Rover.
    7. #47
      May 2011
      Hendersonville, NC
      Beautiful craftsmanship as always. Congrats on a great build!
