Results 41 to 60 of 236
05-10-2018 #41
Patching the time capsule - with actual metal.
05-10-2018 #42The driver side door had been replaced from a donor. It wasn't in much better shape.
It looks a little better now.
05-10-2018 #43I wanted to run power brakes and hydraulic clutch but the car originally had manual brakes and an automatic so my existing pedals were all wrong. I looked at some expensive pedal assemblies that would require a good bit of fabrication to install. I also considered switching my pedals to a stock clutch and power brake setup but that option was nearly as much as a Wilwood assembly. Just as I was about to pull the trigger on a three pedal setup, I remembered I had an old manual brake pedal from the 69 mustang. I played around with it a little bit and realized I could make it work.
Here, the 69 brake pedal is hanging from the stock bracket, mounted the same way an original clutch would be. Only the footpad needs to be trimmed. There is plenty of clearance between the pedals for the steering column. Once I was committed to that configuration, I bought a fox body gas pedal from eBay.
05-10-2018 #44I needed a fairly compact power brake booster so I would have room to mount the clutch master cylinder. I found an old website that described fitting a 93 Mustang brake booster and CNC clutch master cylinder. The only modification required to mount the '93 booster is to drill a few new holes and fill a couple old ones.
It is tight but there is enough room to mount a 3/4" Wilwood clutch master cylinder.
05-10-2018 #45Here's a better view of the pedal assembly.
I reinforced the firewall at the clutch master cylinder mount to eliminate flex.
The pushrod on the clutch MC is too short so I'm using a socket as a spacer for the photo. It's not a permanent addition.
I made a new pushrod from a grade 8 bolt. I just chucked it in my wood lathe and shaped the head with a metal file.
05-10-2018 #46I went through my spare parts pile to find an old brake master cylinder push rod. I cut the loop end off it and welded that to a threaded coupler. Combined with the bolt that I just turned, I now have an adjustable pushrod for the clutch MC.
I'll find (or make) some smaller pedal pads eventually.
05-10-2018 #47I used a brake master cylinder from a V8 94 Mustang.
Here, I've just started bending the brake lines.
05-10-2018 #48Cleaned up the bracket and mounted some smaller footpads.
05-10-2018 #49
