Page 1 of 7 1 2 3 4 5 6 ... LastLast
Results 1 to 20 of 127
    Las Vegas, NV
    67'- 68' Camaro / Firebird Single DIN Radio Mounts
    UPDATED 4-30-20
    First batch of single DIN radio mounts for 67-8 Camaro & Firebird available , now a solution to mount a modern radio head unit for the vast majority of people dealing with a cutup dash from over 50 years of owners! Have better quality, usually with many more options and less expensive than the two shaft type, pm me for details pics of installed unit in a customers 67 before and after he had it & dash pieces hydro dipped when I did a 5th Gen Camaro console install w/ @watsons_streetworks billet p/w switches
    You can paint to match interior, powder coat or hydro dip them
    I will be sending messages to people that contacted me before after I made my first mount, more mounts are being built now
    $145 shipped/ insured/ paypal for bare mount w/ mounting hardware
    message me or
    (702)677-4085
    SOLD OUT as of 9/1/19 Thanks to all the purchased the mount kits
    Jeff
    UPDATE 10/28/19, will be doing more to be available in next week or two
    Las Vegas, NV
    Thanks everyone for the great response on these radio mount kits, will keep building them, Thanks, Jeff
    Thompsons Station, TN
    Feb 2011
    I need something like this but to mount a double din
    Las Vegas, NV
    Quote Originally Posted by davidfre21 View Post
    David,
    I am actually working on a design/ sizing for a double DIN this week, since I have had a few people ask about it
    Is your car a 67-68?
    Thanks, Jeff
    Jonesboro, Arkansas
    Good looking Jeff!
    Carl Wilson
    1968 Camaro - T-56 6 speed - 383 Stroker, 2014 Mustang GT seats
    Mar 2018
    Oklahoma City, OK
    I want to order one. I'd like to see how the double din comes out to see if I want to invest in a new head unit.
    Feb 2011
    Quote Originally Posted by jwcarguy View Post
    David,
    Thanks, Jeff
    It's a 68. I already bought the smooth delete panel to attempt myself but who knows when I'll get around to it. Plan on running vintage air controls.
    Las Vegas, NV
    Quote Originally Posted by 7Knapp View Post
    I will keep you guys posted on double DIN mock up, big issue is covering the lower section of ash tray hole, where it rolls under dash and have it look good
    Thanks, Jeff
    Las Vegas, NV
    david, Here is a pic of a guy's 68 with the VA controls that installed my mount kit
    Mar 2013
    I gotta anvil carbon center dash cover on the way, it's a blank one, I will need to cut opening for center vent and heater controls (dse adapter) in my case
    Rest is still blank and covers the ashtray, there might be enough room to
    Have a opening for a 2din. Will have to wait till I have it in my hands.
    https://anvilauto.com/products/camar...ash-panel.html
    Nov 2014
    Lake Worth, FL
    Are you going to make any for a Double Din radio??
    Scott
    Feb 2011
    See, I don't care about the ashtray. It will be deleted with the new panel. But because of it, I'll have all the room from the VA controls down. Or I can mount the VA controls in the ashtray area and have all the room going up.
    Las Vegas, NV
    Quote Originally Posted by Camaro68+69 View Post
    Scott
    Working on design now
    As you all know, issue is lower most opening ( bottom of ashtray hole) to make look correct and not a huge fabrication job with rolling lower section of bezel, etc?
    Open for suggestions?
    Thinking of having same outer bezel width at bottom, but maybe a separate piece ( as a block off) for lower ashtray opening, wich is hard to see when seated in car, especially with a console installed as well
    Los Angeles
    Is trimming needed if the radio section of the dash has not been molested?
    Las Vegas, NV
    Carl
    Yes, the height of hole is 2 7/8” ( mesaured from upper horizontal dash structure, down , to line to trim) yhe upper dash structure remains intact
    The width of hole is 8” ( centered)
    Slight trimming on sides ( factory round holes for stock radio shafts) to clear side theeaded mounting bosses , that are part of the mount
    I made up a “ install sheet” with diagram, dimensions and instructions
    Jeff
    Dec 2011
    sweet I've been looking for something like this.
    Las Vegas, NV
    Quote Originally Posted by oldschoolmuscle View Post
    Still have radio mount kits left
    Pm me for ordering
    Jeff
    Las Vegas, NV
    weekend bump
    Las Vegas, NV
    weekend bump
