    Page 2 of 6 FirstFirst 1 2 3 4 5 6 LastLast
    Results 21 to 40 of 107
    1. #21
      Feb 2014
      Boise , Idaho
      Will your power steering pump clear the steering box in that configuration?
      Looks great so far!
      About to make poor choices and regrettable decisions
    2. #22
      Oct 2015
      Here is the start of my exhaust. It's 3.5 stainless oval pipe. It's done to the mufflers , now I have to figure out how to get tailpipes done due to no clearance anywhere.
    3. #23
      Oct 2015
      Paraman 1, yes it does clear but not by much, about an half inch of clearance . Here's a pic that kind of shows what it looks like.
    4. #24
      Oct 2015
      Paraman 1 , I forgot to say that the motor has adjustable mount set all the way back. Also I set the lower mount back 1 to 1 1/2 inches back to get motor as close to firewall as possible. It was dumb luck that it cleared but when I got kit from Wegner he said I may have to put on pump with remote reservoir. I can run what I got but I wil have to move return to back side of pump reservoir .
    5. #25
      Aug 2015
      NJ
      I had the same issue with my exhaust and decided to do turnouts in front of the rear tire. Man I could not be happier with the look and the sound is insane. Since you already have ovals - check out Spintech for mufflers unless that is where you bought the oval pipe from already lol. I have a set on mine and like I said - it sounds insane.
    6. #26
      Oct 2015
      Here's some pics of the firewall
    7. #27
      Oct 2015
      After I slid motor back to firewall, trans tunnel had to be altered to clear 4l80e.
    8. #28
      Oct 2015
      Well I think I lost my mind, this is my solution to my tailpipe issue that I came up with. The height of the floor will not be higher than the original center part of the floor unless there is an unforeseen problem that I didn't think of. The tip thru the sides are not done yet. I haven't decided how to finish yet.
    9. #29
      Jan 2017
      pickering ontario canada
      Drooollllll
      1971 chevelle LSA 700hp -
    10. #30
      Jun 2014
      OMG!!! that exhaust is a thing of beauty. awesome build. What primer are you using btw?
    11. #31
      Indiana
      That's an interesting way to route the exhaust. I like it!
      Herb
      1966 Chevelle 509/T56Magnum
      1963 C10 454/4L80
      PHR CHP CHP youtube
    12. #32
      Oct 2015
      Thanks for the compliments. 2ndroundko , I'm not sure what btw means ( sorry I'm not to smart) , the car was primered when I bought it and haven't touch that part yet.
    13. #33
      Jul 2007
      Phx AZ
      Some very nice fab work ! It’s lookin great sure would like one of those super chargers !
    14. #34
      Aug 2015
      NJ
      Really cool fab stuff goin on here - keep at it man - looks sick!
    15. #35
      Oct 2015
      Couple more pics of exhaust
    16. #36
      Jun 2014
      Btw=by the way lol
    17. #37
      Oct 2015
      Got the floor finished covering the exhaust. The tunnels covering the pipes are same height as the origin center part was, hopefully I can make a seat work.
    18. #38
      Oct 2015
      Here's some pics of what I've been doing lately. I put engine oil cooler in left front wheel well, still waiting on oil filter adapter with built in oil primer from Peterson. I also mount a 2017 camaro steering column and wheel. I'm not excited about camaro part but really like the wheel. It's got tilt and telescope, all the switches necessary to run everything and paddle shifters. Best part is that it was only $250 for everything .
    19. #39
      Oct 2015
      Some more pics
    20. #40
      Oct 2015
      Couple pics of remote oil filter adapter with a built in primer, should work great after oil changes and after sitting over winter.
