02-02-2018 #1
1970-1981 Fbody Camaro and Firebird Speaker Kickpanels and Speaker Package Tray
$165 shipped a set to lower 48 - can ship to Canada and other places for the additional cost of shipping
Fits 1970-1981 Camaro or Firebird
No Speakers are included, these are raw panels ready for you to finish and add your own speakers
Comes with both kick panels, pinch weld and instructions, will be finished in a smooth white gel coat primer and it’s up to the end user to finesse the fit and cover in vinyl or paint.
Some prep will be need if painting as you would any fiberglass part.
If you decide on vinyl and want to match the factory door panel grain you are going to want to use sierra grain vinyl on later cars and madrid grain vinyl on early cars.
Some trimming required to get a tight fit to your car
Parking brake can be retained, you may have to shim it out or bend it a bit to gain clearances over the speaker grille.
Holds a component set with a tweeter and 6.5” speaker and up to a 7” diameter grille.
Will work with Factory AC but you need to remove the flapper actuator in the passenger kick panel and cap off the vacuum line.
If you have factory non AC you will need to get creative with the fresh air vents pull knobs, in most cases you will lose them unless your able to come up with something. I am not familiar with those systems.
If you have Vintage Air, no problem that's what I put on my personal 71 Camaro and I provide instructions on how to mod the set-up to work with these kick panels.
To protect the rear of your speakers you just need to purchase a set of Metra 81-6900 Speaker baffles, they fit perfectly inside the opening and give the speaker something to play into, while protecting it from the elements. You can get these on eBay from various sellers for around $10-12 shipped.My build thread
http://www.nastyz28.com/forum/showthread.php?t=241037
Paint Jail Experience
https://sites.google.com/site/paintjail/home
02-02-2018 #2Speaker Package Tray
Speaker Package Tray $200 shipped to lower 48 States
Holds two 6.5" speakers flush on each side and has a center cut-out for a subwoofer to fire through
Made of strong water proof fiberglass, will not warp or fade like the factory cardboard piece
* Some minor prep and / or sanding will be needed like any fiberglass part before painting or covering, that includes but not limited to priming, and fixing small blemishes in the finish..but any of this is to be expected with molded parts.*
You can paint or cover this in the materials of your choice so it will be up to the end user to fit and finish to their liking.
Compliments the speaker kick panels I also sell for a well rounded car audio system
Comes in white gel coat with a mdf grille blank for the subwoofer.
Modifications to the rear deck around the 6x9 openings and center of deck will be required if you desire to use a subwoofer.
PLEASE NOTE ANY PICTURES OF A FINISHED PRODUCT IS FOR REFERENCE ONLY, INCLUDING THE GRILL. YOU WILL BE GETTING A 1/2" MDF PIECE OF WOOD AS A TEMPLATE TO FABRICATE YOUR OWN GRILL TO YOUR LIKING. NO MATERIALS OR GRILL CLOTH IS SUPPLIED AND UP TO THE END USER TO SOURCE THAT.
I do not sell these finished out and covered as I simply don't have time to do that and fitment and prep is key...it needs to be done before they are covered, sale is for the panel as you see it.
It will be up for the end user to source someone to complete the installMy build thread
03-13-2021 #3Registered User- Join Date
- Jul 2012
- 2
